Ford 8.8 load capacity - Ford Truck Enthusiasts Forums
Old 01-11-2004, 01:05 PM
tkyllo tkyllo is offline
tkyllo is starting off with a positive reputation.
Question Ford 8.8 load capacity
Can anybody tell me where to find weight ratings for this r.e? Or, do you have any guesses how heavy I can go before it folds in half?
Old 01-11-2004, 03:43 PM
Dustin_86 Dustin_86 is offline
Dustin_86 is starting off with a positive reputation.
3800Load cap.
abou7500LBS axle folding pressure
Old 01-12-2004, 08:29 AM
Thanks for the info. I'll try to avoid wrecking it. I noticed you've swapped a Dana 60 into your f150. Did it take many modifications? I've got a couple around, just didn't plan on putting one in my wood hauler, but maybe it's a better idea. Any tips?
Old 01-12-2004, 09:09 AM
No just the spring perches and the U-joints are larger so I went with a 74 NP435, a 2 piece HD drive shaft outa a 75 F350.That was about it.It was HEAVY I had Me, MY step dad, and my mom helping me roll the sucker underneath.I left the tires on-it rolled alot easier
Later
Dustin
Flexplate installation on a 302 V8 seschenburg 1987 - 1996 F150 & Larger F-Series Trucks 2 09-22-2016 09:54 AM
distributor ? bigfoot7180 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-12-2011 04:15 AM
8.8 Limited Slip Diff brucewolff 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 12-04-2006 04:16 PM
Ford 8.8" vs. ford 9" Huntersbo Offroad & 4x4 28 07-11-2006 09:04 PM
?????Need C-Clip Eliminators 8.8 Truck ????? ProVW Clutch, Transmission, Differential, Axle & Transfer Case 21 08-16-2003 09:56 PM
Tags
88, capacity, ford, load, rating
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
