Is there an on-line diagram that shows the layout of the complete lock and connecting rod assy? My driver side lock actuator rod is disconnected and i can't find a diagram that shows me how it should go.
If you look at the door mecanism there should be a plastic clip that the rod should snap into. Try locking and unlocking the door manually. The arm the rod connects to should move up and down. Hope this helps.
