inner fender liners
Old 01-10-2004, 10:48 PM
Josh79's Avatar
Josh79
Josh79 is offline
inner fender liners
the plastic inner fender liners on the front of my 79 f 150 are not in very good shape. they are cracked up and they fell off after some serious mudding. i have put new screws in them and they stay on for awhile but eventually they fall back down. i was wondering if you guys knew where i could get new innner fender liners for a 79 f 150. i looked in my lmc magazine and they have a thing they call a fender seal set w/ fasteners. is this what i am looking for? it looks like it is only in the back of the fender and not the whole thing like the fender liners that i have. any info on where to get them would be appreciated.
Old 01-10-2004, 11:11 PM
rainbowATF's Avatar
rainbowATF
rainbowATF is offline
inner front fender
Upper Right Corner=Parts Shop: Motorhaven. Do search on "inner front fender" in Motorhaven. They are $99 each
They are plastic; could try hot glue and fiberglass repair for quick and dirty repair to lengthen their life for awhile.
Old 01-11-2004, 12:30 PM
shane74's Avatar
shane74
shane74 is offline
Lightbulb iner fender skirt locator technique
josh79 if you know any body shop owners you might check with them. most shops have after market resourses . i know the one i work at does. it will be a day or so before i can get the info for ya.but i wiil forward it to you.
Old 01-11-2004, 12:37 PM
shane74's Avatar
shane74
shane74 is offline
you can also hold the iner fenders on with what are called christmas trees you can get them at any body shop . they will alow a little more play when you get in a bind. wont tear up as bad when they get jerked off the truck. yes it happens from time to time
Old 01-11-2004, 01:54 PM
Josh79's Avatar
Josh79
Josh79 is offline
well i put bigger screws in the right side yesterday cuz they popped off and they stayed on. but today the left side popped off and the outside edge where the screws go in is pretty much gone so i am going to have to find new ones asap
Old 01-11-2004, 07:57 PM
Josh79's Avatar
Josh79
Josh79 is offline
i also found them @ macs but they are 112 each. is this the price range i should expect? i might just have to go find a decent used set @ the junkyard because i am looking to invest my money in a snowmobile
Old 01-11-2004, 08:17 PM
Josh79's Avatar
Josh79
Josh79 is offline
ok i was looking in lmc and they have listed their styleside rear splash shields. i was curious as to whether they would fit the front or not? they look different and are two pieces but would they fit or not?
Old 01-11-2004, 11:14 PM
ivanribic's Avatar
ivanribic
ivanribic is offline
I looked at my rear splash shields and they do not look like they'll fit the front. You might check the classified section of FTE if you don't want to pay $100 a piece. There are quite a few 70's trucks being parted out and I would bet you can find these there.
Old 01-12-2004, 12:03 AM
Racerdave's Avatar
Racerdave
Racerdave is offline
If I were you, I would buy some fiberglass, resin, and a can of bedliner. It worked for a friends jeep. The only tuff part of the job was makeing the molds. Just a thought....
Old 01-12-2004, 11:49 AM
Josh79's Avatar
Josh79
Josh79 is offline
well im just ordering them through a local body shop here. still about the same price but o well. its a pretty expensive piece of plastic though
Old 01-12-2004, 11:55 AM
grapegravy's Avatar
grapegravy
grapegravy is offline
I agree with Racer on this one, luckily, you already have the mold of the fender liner. This is one of the projects I have lined up for the spring, simple enough. Plus gaining the experience of doing something like this can help down the road from paying a big bill for a replacement panel and such.
Old 01-12-2004, 02:51 PM
Monster 78 F-150 4X4's Avatar
Monster 78 F-150 4X4 is offline
you could probaly get them at the bone yard very cheap if you can get the screws out, I didnt realize they were worth anything because i killed a good set geting them out of my parts truck trying to get the fenders off.
Old 01-17-2004, 05:21 PM
Josh79's Avatar
Josh79
Josh79 is offline
well the local body shop owner went down to omaha and found a good set for 50 total instead of over 200 for new ones
Old 01-18-2004, 05:13 AM
Alphy's's Avatar
Alphy's
Alphy's is offline
Would those inner fenders fit in my 73 F100? They sure look like they could keep alot of dirt out of the under side of the finders.
MikeBomba
16
07-11-2017 06:50 AM
Kountryguy
1999 to 2016 Super Duty
04-17-2016 12:18 AM
danorules
2004 - 2008 F150
02-18-2013 11:34 AM
PokeSalad
06-04-2012 12:20 PM
alconk
15
10-09-2008 09:30 PM
Quick Reply: inner fender liners
