front end shimmy/vibration on right curves - Ford Truck Enthusiasts Forums
Old 01-10-2004, 08:51 PM
donnor donnor is offline
donnor is gaining momentum as a positive member of FTE.
I have a persistent problem with my 95 F350 Crew Cab, 2WD. Since about ~160,000 miles occasionally I get a mild to severe vibration in the front end while driving at 45-65 MPH in a right hand curve. Cranking the wheel just a bit either way brings it right out. It has never occurred in a left curve. We've tried rebalancing tires, new tires, rotating tires, front end alignment (it was right on the money). All steering components are tight, ball joints, bearings, & axle pivots also all tight. Front stabilizer has all new urethane bushings & I also put on a steering stabilizer/hydraulic damper. New shocks made no difference. Radius arm bushings & nuts are also all tight. The truck tracks well at highway speeds with virtually no drift or pull. No unusual tire wear has been noted: I get ~50,000+ miles out of each set of Hercules LT235R-85 16s that I put on it, rotated front<->rear every 6,000 miles; pressure maintained @ ~70 psi (Load Range E). The truck now has >280,000 miles on it.
Overall I like the truck & have no plans of replacing it. This is not a big thing, just an occasional irritant. Any thoughts? Others with similar problem?
Thanx,
dn.
2003 super bad wobble/sway. Help! Brokeacehorses 1999 to 2016 Super Duty 5 12-11-2015 12:45 PM
Occasional Weak Power Steering and Surging toocheaptosmoke 1987 - 1996 F150 & Larger F-Series Trucks 1 11-25-2015 08:17 PM
shaking/wobbling going around curves Cattle Rancher 82 1987 - 1996 F150 & Larger F-Series Trucks 3 07-02-2012 04:58 PM
slight vibration - feels like front end Camp250 Excursion - King of SUVs 25 02-07-2012 09:03 AM
stabilizer broke - big problems? jasvid 1994.5 - 1997 7.3L Power Stroke Diesel 12 04-03-2010 07:41 AM
Tags
45, 95, bronco, cab, curves, driving, end, f150, f350, ford, front, mph, quad, shimmy, vibration, vibrationshimmy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
