Resetting Tire Pressure Monitor (Ford Techs?) - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 01-10-2004, 02:01 PM
ExpyBob ExpyBob is offline
ExpyBob is starting off with a positive reputation.
Is there a way to do this without special tools?
If not where can you buy the tool?
Can someone explain this procedure and when it should be done. Some cars need it even after rotating the tires. Since their systems provide a specific pressure for each wheel.
The Ford system just says "Low Tire Pressure" you have to figure out which one.
Please help---Bob
Old 01-10-2004, 02:13 PM
Keydo Keydo is offline
Keydo is starting off with a positive reputation.
Ouch, it doesn't even tell you which tire or transmitter is indicating the low tire pressure?
I liked the idea of tire pressure monitoring, but did not like the fact that when you change wheels, the monitoring system was permanently installed on the stock wheels.
Which means once you go aftermarket wheels, you've disabled the tire pressure monitoring system.. Ugh.
Old 01-10-2004, 05:57 PM
daveplot's Avatar
daveplot daveplot is offline
daveplot is starting off with a positive reputation.
From the service dvd...
Sensor Training
NOTE: The tire pressure monitoring system is not affected by wheel and tire rotation.
NOTE: The tire pressure sensor training procedure must be done on a single vehicle, in an area without radio frequency (RF) noise.
RF noise is generated by electrical motor and appliance operation, cellular telephones, and remote transmitters.
1. Turn the ignition switch to the OFF position.
2. Turn the ignition switch from the OFF position to the RUN position three times, ending in the RUN position. Do not wait more than two minutes between each key cycle.
3. Press and release the brake pedal.
4. Turn the ignition switch to the OFF position.
5. Turn the ignition switch from the OFF position to the RUN position three times, ending in the RUN position. Do not wait more than two minutes between each key cycle.
6. Wen the message center displays "TRAIN LEFT FRONT TIRE", place the magnet on the valve stem of the LF tire pressure sensor. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the TPMS module.
7. Within two minutes after the horn sounds, place the magnet on the valve stem of the RF tire pressure sensor.
NOTE: If the TPMS module does not recognize any one of the five tire pressure sensors during the tire training procedure, the horn will sound twice and the message center will display "TIRE TRAINING MODE INCOMPLETE" and the procedure must be repeated.
8. eat Step 7 for the RR, LR, and spare tires.
When the tire training procedure is complete, the horn will sound once and the message center will display "TIRE TRAINING MODE COMPLETE".
The only tool you need for this is "Activation Tool, Tire Pressure Monitor 204-324" which sounds like a magnet that screws onto the valve stem.
Unfortunatly the system only says: Tire Very Low, Check Tire Pressure, Check Spare Tire Pressure, or Tire Pressure Sensor Fault.
Old 01-10-2004, 06:01 PM
daveplot's Avatar
Quote:
Actually it can be removed and reinstalled on a new wheel. The way the service manual showes, it just hangs from the valve stem.
Old 01-10-2004, 10:21 PM
Daveplot
It worked just as you said.
Thank you, Thank you and Thank you.
It did not look for the spare tire. After the four tires it said it was complete.
You would think that if you calibrate the tires in accordance with LF, RF, RR ,LR it would know which tire is low. But it don't.
Where do you get the CD srvice Manual.
Thanks again----Bob
Old 01-10-2004, 11:20 PM
daveplot's Avatar
The service manual is from Ebay. If you search for 03 Ford DVD you will find it.
Mine is the 03-04 version (September Version 8)
The only drawback of the DVD is it "expires" so you have to set your computers clock back to use it. Each version "expires" a month after it's released. So when I use mine, I just set my clock back a year.
Old 01-12-2004, 11:03 AM
ms6073 ms6073 is offline
ms6073 is starting off with a positive reputation.
Quote:
I got an official Ford Facotry Service DVD (the same one used by techs at Ford dealerships) by making a donation to the folks at Flatratetech.com. I got mine mid-year last year and it covers all Ford products produced between 96' & 03' and I have not experienced any type of expiration problem with it!
Michael
Old 01-12-2004, 12:57 PM
daveplot's Avatar
Yes, that's the same type of DVD I have. Ford started putting expiration dates on any DVD after July 03 I believe. So that would include much of what is out there now.
Old 01-12-2004, 01:31 PM
Oh no - well that certainly bites! Another reason for technicians to be upset with Ford!
Michael
Old 04-09-2006, 02:11 PM
peakay peakay is offline
peakay is starting off with a positive reputation.
I have this issue wiht our expy - can someone tell me where to get this magnet or other devise that allows me to rest the sensors? I bought a set of navigator wheels with the sensors in and though tthey would just work -- now i need to reset them.
TPMS reset... or not JD BuckSavage 2017 Super Duty 1 12-14-2016 12:10 AM
Need to reset TPMS after tire rotation Tom 2015+ F150 18 12-11-2016 05:39 PM
TPMS SENSOR TOOL gene daniels 1968-2013 Full Size Vans 2 10-11-2012 10:34 PM
Tire Pressure Monitoring System nut1605 6.7L Power Stroke Diesel 11 11-28-2010 11:06 AM
Tire Pressure Monitor Reset (Ford Techs) ExpyBob Brakes, Steering, Suspension, Tires, & Wheels 0 01-10-2004 02:04 PM
Tags
2008, 350, directions, e350, ford, instructions, moniter, monitor, monitoring, pressure, reset, resetting, tire, tpms, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
