Manual Choke vs. Electric
I just acquired a Holley 2300 "list 8226" which was an OEM carb on 74/75 F series trucks. This carb was factory on 302 c.i. as far as I can tell. The guy I bought it from pulled it off of his running 390 c.i. when he put on a 4 bbl & manifold. This carb has the choke mechanism that attached to a heat riser tube. My current autolite has an electric choke. I know that a Holley 45-226 electric choke kit is what I need to convert existing choke...however I am thinking about putting a manual choke on it instead. Any pros and cons regarding electric vs manual choke that I need to consider?
a manual would be fine, specially on cold start-ups, you can use it as kind of a throttle control, so u dont have to have your foot on the gas till its warm. i have one and i like it better than the electric choke, i had to many problems with it, and i have had no trouble with the manual one ever.
Sportsterengr
02-04-2016 01:20 PM
Mdc9966
09-16-2015 11:20 AM
