removal of front brake rotors '97 f250 4x4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-25-2002, 06:11 PM
nickdoni's Avatar
nickdoni nickdoni is offline
nickdoni is starting off with a positive reputation.
Old 08-28-2002, 08:37 PM
1997 F250 1997 F250 is offline
1997 F250 is starting off with a positive reputation.
Post removal of front brake rotors '97 f250 4x4
I need help getting the rotors off. There is a lock nut that is a circle with a notch cut to the inside of it and I can not figure out how to get it off... Any suggestions welcome... Thanks
Nick Mtbiker80(No Email Addresses In Posts!)
Old 08-28-2002, 09:04 PM
Yeti's Avatar
Yeti Yeti is offline
Yeti is starting off with a positive reputation.
>welcome... Thanks
Welcome!! Mtbiker...what do you ride?
On to your question:
Is it a nut or a lock washer (holes around it where pin from nut fits?
If it's the washer, I believe it just slides out or off the nut.
If I rember correctly, there are 2 nuts with the washer in between.
First nut comes off then you slide the washer out, then you can get to the second lock nut.
Carefull putting them back together, the washer needs to slide on the pin just right.
Hope this helps..if not Im sure someone else will be along to correct me.
Old 08-30-2002, 08:34 AM
BKeyes BKeyes is offline
BKeyes is starting off with a positive reputation.
You need a special tool to take the hub nuts off. It looks like a socket and fits on a 1/2" drive socket but has four square pins extending on the outside of it. They come in two sizes, one for the heavy duty/super duty trucks and a smaller one for half-tons.
Previous post is correct in that you remove the outer nut, then the locking washer, then the inner nut. The same tool is used for both the outer and inner nut, and the washer just slides off.
Once the nuts have been removed, the hub slides off (note that the inner bearing will come out also). To change the rotor from this point requires that the lug bolts be pressed out (I used a hammer and large punch to knock them out). The new rotor is then put on and the lug bolts pressed back in. Make sure that the lug bolts are pressed back in all the way, or you may have a problem with them spinning in the hole when the lug nuts are tightened up.
Hope this helps.
4x4. 4x4 Off Road. 4x4 Sport. fx4. 4x4 STX Irish816 Offroad & 4x4 17 05-19-2010 08:08 AM
celebrating holidays in schools 4x4x4x4 General NON-Automotive Conversation 28 12-16-2002 01:54 AM
What IS Flutter?? 4x4x4x4 Modular V10 (6.8l) 6 04-16-2002 10:29 PM
swap... brown 4x4 Ford Inline Six, 200, 250, 4.9L / 300 2 12-25-2001 11:54 PM
Awesome 4x4 expedition DBUCKWILD 1997-2006 Expedition & Navigator 2 11-26-2001 08:32 AM
Tags
1997, 4x4, 97, brake, change, duty, f250, f350, ford, front, removal, rotor, rotors, stuck, super, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
