Go Back   Ford Truck Enthusiasts Forums > General > Ford vs The Competition
Sign in using an external account
Register Forgot Password?
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
  #1 (permalink)
Old 01-09-2004, 02:06 PM
93F-2507.3diesel 93F-2507.3diesel is offline
Garage is empty, add now
93F-2507.3diesel is starting off with a positive reputation.
Question wrong info
wrong info on this page originally
Josh
93 F-250 ext cab 7.3L Diesel 4wd
  #2 (permalink)
Old 01-09-2004, 02:10 PM
Hoss Got a Cummins Hoss Got a Cummins is offline
Hoss Got a Cummins is starting off with a positive reputation.
Some things just aren't worth commenting on.
__________________
- Hoss
  #3 (permalink)
Old 01-09-2004, 02:22 PM
Quaddak Quaddak is offline
Quaddak is starting off with a positive reputation.
For one, the 5.9 Cummings is a heavy duty industrial diesel engine, the PSD is a light duty automotive engine.
The 5.9 very comparible in street form as far as performance. However, it has proved that it can be tuned to smoke a lot of performance sports cars which the PSD light duty engine it is not capable of handing the level of performance the cummings can generate.
Cummings is a pure diesel engine.
Builds it's peak HP and Tq at a much lower RPM than either Ford or GM. (According to the Ford 5.4 boys that along makes it king)
Another thing, I6 vs V8. 25% less moving parts.
Don't get me wrong, for what they do they are both adequate and very capitable.
Why don't you enlighten us on your opinions?
My dad has 96 5.9 that has been dynoed at 303 HP and 686 ft lbs at the rear wheels.
  #4 (permalink)
Old 01-09-2004, 05:57 PM
otto otto is offline
otto is starting off with a positive reputation.
I would say the T444E is also a heavy duty inductrial engine, Many international dump trucks, school buses, straight trucks and fords use them, I would say the only place the cummins is and the cornbinder isnt is lobster boats and construction equipment, we have a case wheel loader at work with a 5.9 in it, worked to death and its no fun to start in 25 degree weather , im not sure it has a grid heater like a dodge does tho.....i hold it toe boards and get it cranking and sometimes it goes, when it dont give the ether button a few pushes.........once it starts knocking it may be running under its own power, hold'er down till it builds full rpms then feather it to keep it alive till it will idle
The T444E is offered in two axle trucks. As a single unit straight truck the practical and legal limit for weight carrying capacity is 35,000 Lb. A vehicle with 52,000 to 65,000 Lb. rating would have to be a three axle straight truck or a two axle tractor with semi- trailer. The truck model that the T444E is offered in is also available in a tractor configuration. When the two axle tractor is coupled to a tandem axle trailer the GCW could range up to 65,000 Lb. There are no published restrictions in the International system advising against using the T444E as a tractor, an order can be specified with the engine in a tractor and customers have purchased them. So, the bottom line is the T444E is actually approved, and customer applied, in ratings up to 65,000 Lb.
Claim: Cummins has built 1.7 million 6B engines. Numbers game alert! What they're counting here is all B family history including four cylinder engines and non-highway applications such as farm and industrial equipment. When the total volume of six cylinder B family engines used in automotive applications, including the pickup truck market, is considered their volume number is more like 800,000. And that's for the previous B family. The ISB is, by their own description, a significantly new product. As for the T444E; counting engines sold in the on-highway automotive use category, the production volume exceeds 740,000 for the existing continuing product.
__________________
Ford Truck Listing Only Here
  #5 (permalink)
Old 01-09-2004, 06:21 PM
92f150I6's Avatar
92f150I6 92f150I6 is offline
92f150I6 is starting off with a positive reputation.
You do know that the 7.3 is a converted International harvester industrial Gas engine, right? Don't believe, me look it up. I read it in a truck book at Barnes and noble. 443 or some odd cid gasoline engine, but it's internals are strong enough to be come a diesel.
as to the numbers game thing, It really doesn't make sense. They said 6B engines, which means 6 cyl B series engines to me.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
09 Challenger RT
A bunch of motorcycles, other cars, and a Quad.
  #6 (permalink)
Old 01-09-2004, 06:26 PM
MJD MJD is offline
MJD is starting off with a positive reputation.
I have heard that a 7.3 is very similar to a 3208 Cat. Has anyone heard anything about this?
__________________
1993 F-150 Ex. Cab SB 4X4, 302 auto-finally traded off
1986 F-250 ex cab 4X4. 460 4-speed manual
2004 Dodge Cummins
  #7 (permalink)
Old 01-09-2004, 06:57 PM
TowinBob TowinBob is offline
TowinBob is starting off with a positive reputation.
I sure hope somebody that spells Cummins "Cummings" does not even drive a diesel let alone own one.
Ford sold over 1 million 7.3 PSDs from 94-03.
Dodge sold 1 million CTDs from 89-03.
Factor in all of the T444Es in busses and MDTs on the road and it seems there are a lot more of them than the 1.7 million 5.9s in the world in all applications.
__________________
1993 F150 4X4 302 AOD
Made in the USA
  #8 (permalink)
Old 01-09-2004, 07:17 PM
Innuendo: Cummins refers to the T444E as having a gasoline engine heritage. Huh?! Where does this come from? There is no part, process, displacement, or machining operation in the T444E that is common to any gasoline engine International ever built. The only commonality is that the T444E is manufactured under the same roof of the Indianapolis plant where the finest gasoline engines used in the medium truck market were once made.
Only thing the T444E and Cat 3208 have in common is that they are a medium duty V8
__________________
  #9 (permalink)
Old 01-09-2004, 08:28 PM
rancherman84 rancherman84 is offline
rancherman84 is starting off with a positive reputation.
something else they have in common,the ih and cat both use the heui style injector but the cat uses a third rocker arm to operate the injector while ih uses oil pressure from a high pressure pump.
__________________
2002 F-150 4X4 EXTENDED CAB,STEPSIDE with 7.5 CURTIS SNO-PRO PLOW
  #10 (permalink)
Old 01-09-2004, 09:07 PM
MJD MJD is offline
Quote:
Thats about the same thing that I have heard. I think that the 7.3 or nearly any diesel is superior to the 3208. They were a boat anchor.
__________________
2004 Dodge Cummins
  #11 (permalink)
Old 01-10-2004, 06:49 AM
Quote:
Yes it is i had a 3208 cat ran strong too. A 3208 is a 7.2L with 210hp and very high in tourqe. I dont rember the tourqe rating on it. I had it in a 1980 GMC Brigader sevice truck. Could go down the highway with 33,000 pounds doing 67mph. Not bad for that bone but its gone now.
Josh
  #12 (permalink)
Old 01-10-2004, 12:23 PM
every manufacurer built a boat anchor at one time or another.i am ford and navistar all the way but you couldnt give me a 351m or 400m gas motor.i had an 84 f250 with a 300 6cyl and loved it 300,000+ miles until swapped up to my 92 f250 diesel and love it to.kinda off the subject but it is all opinion on which motor is a boat anchor or not,the cummins is not a boat anchor by any means,but that duramax, well i dont know , aluminum heads on a diesel,come on!
__________________
  #13 (permalink)
Old 01-10-2004, 08:52 PM
MJD MJD is offline
you may have misunderstood me. I meant to say that the Catepillar 3208 was a boat anchor. Their average overhaul intervals were 1000 hrs or less. I personally think that Duramaxes are a great motor. I am not too keen on the aluminum cylinder heads either, but so far there have not been any signifigant issues with them. Time will tell.
__________________
2004 Dodge Cummins
  #14 (permalink)
Old 01-10-2004, 10:24 PM
MW95F250's Avatar
MW95F250 MW95F250 is offline
MW95F250 is starting off with a positive reputation.
Wrong. A 3208 Cat is 636 cubic inches, 220 horsepower, 7.3 is 444 cubic inches.
Actually, the 3208 in our '87 C-70 Dump truck is a good engine. Almost 200k, only problem was the governor relay went bad at 185k. Wish the cab would hold up as good as the engine does.
__________________
2004 F-250 XL Regular Cab Longbed 4x2 6.0L Power Stroke Diesel/Torqshift Automatic, Straight Pipes, 3.73LS, Tekonsha Prodigy
John Deere Ag, CCE, and CF Certified Technician
Kohler Certified Expert Technician
  #15 (permalink)
Old 01-10-2004, 10:39 PM
MW95F250's Avatar
Quote:
Wrong again. The 6.0L PSD (VT-365) was in International Medium Duty trucks 2 years prior to being introduced in the Ford SD lineup.
I talked with an International engineer at a trade show this past fall, he showed me the internals on a cut-away block side by side, the 6.0L is a heavier built engine than the 7.3L, he said the 7.3L was impossible to clean up for emissions and that was the reason behind the 6.0L being developed. The 6.0L has a beefier crank and rods than the 7.3L. Also, the 6.0L has a unitary design in the lower end, it is VERY stout. He said it does lack power in the larger truck applications, such as tandem axle trucks, but for most medium duty applications, he said the 6.0L was an improvement over the 7.3L. He drove a '03 F-350 6.0L pulling the 18,000 lb. show trailer from Ft. Wayne to Detroit, to Birmingham, to Louisville, where the show was at that I went to. He said even though it was over the weight ratings of the truck, it handled it great.
I asked him about the 6.0L bugs, this is what he had to say: The split-shot injectors are the primary reason for the problems. The '04 engines will have the non-split shot injectors, which will increase noise, but will make the engines more reliable and make the power that is claimed.
__________________
Tags
1993, 220, 59, cubic, cumins, cummings, cummins, cutaway, displacement, f250, grid, heater, inche, love, maintenance, overhaul, people
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
