Why do people hype over Cummins 5.9 there not that good.
#123
mischief bandaged
While i still spell badly I can confirm the german engeering of fords and the host of supply companys like delphi and behr who
fabricated ford parts and supplied a ford motor with a bottom bolton structural plate. bosh injectors bosh high pressure fuel pump and sensors.
if you think all that is bad you should have heard the hell i got for saying that a duramax is a jap version of a 6.5 gmc, now that was ugly
#124
They "Hype" over them because they ARE that good.........How many folks have dropped 5.9 Cummins into assorted Fords, Chevy's, Dodges? Lots of them! When was the last time you heard of a Duramax getting put into a Ford or Dodge, or a Powerstroke being installed into a Dodge or Chevy? Say what you want about the various trucks, but any diesel mechanic will tell you just how good a 5.9 Cummins is
#125
Factor in that they go into a dodge that is not as well built as a ford. There is a 52.9% chance it won't even make it to the jobsite. Running or not.
#126
#127
I also started it one time when it had been sitting for two or three days at about 0 degrees (not plugged in). I let the grid heater cycle once and it took right off. It had 15-40 too. Try that with an IDI.
#128
#129
Received 3,101 Likes
on
i do it all the time. my block heater has not worked since around 1990.
my truck will fire rite up at 15 below zero with valvoline all fleet 15-40 in it.
#130
Aaaahhhh blasphemy its impossible only a cummins can do that. As long as the wiring dosent fail so it can't be started or as long as you have a tow vehicle to pull start your dodge.. Kinda makes you wonder why you would want to keep one of those around huh?
#132
on
yea.
just like how every cummings powered dodge ever made gets 45+ miles per gallon, while making 950hp and 1400 ftlbs torque on the dyno.
but they can't show you the dyno slip because they misplaced it.
and we all know that black smoke means power. the more black smoke your diesel makes, the more hp it makes.
#133
#134
#135
on
