Roadmaster Active Suspension & F250
I have a Roadmaster Active Suspension package (3/4 ton model) that I removed from my F150 before I sold it (I planned ahead and bought the heavier Roadmaster package). I now have a 2001 F250SD 2 wheel drive with the V10 & 3.73 rear-end. Roadmaster says that I can install this kit on my truck but would have to remove the overload spring. My reason for buying a 250 was pulling a 7500# travel trailer - I don't put alot of cargo in the back - just wanted the GVWR & power of a V10!! Anybody out there with the Roadmaster on a 250? I'm planning to install mine when it's time to rotate the tires. Just wanted to hear any feedback on someone that's already done it!
Thanks,
Jim
Thanks,
Jim
From what I've read about the Roadmaster Active Suspension I thought it is similar to an overload spring. Neither one of them is used until you put a load on. Maybe the Roadmaster would start working earlier than the overload though. I guess I would stay with the overload, but I've already have that Maybe you could put the Roadmaster on and try it out and compare the two. I guess I'm a little suprised they make one for the 1999 and up Super Duties, I didn't think they did the last I looked, but that's been a while. Good Luck.
