Vulgar Display of Power
That is what I want you to think of when you see my truck screaming down the street. I think it might be fairly attainable. I got SUPER bored today, and decided, if I had the money, how would I spend it on my truck. Here is what I came up with, and yes, some of these items are in the sights of my credit card:
Vortech SC
Roller Rockers
10# Boost pulley
Auburn Pro LSD
90mm MAF tuned for injectors
42# Fuel Injectors
Diablo Dual Custom chip from Ken (in the works)
70mm TB
3.73:1 Gears
MSD Ignition
hi-perf flywheel
larger brake system, full discs
hi amp alternator
electric fans
aluminum driveshaft
anti-roll locker
booooost, fuel pressure guages and accessories
NOS system
Mariah Carey (souly for exterior photos, dress-up, and "other" things for inside the truck)
Just to clarify, this isnt in any order of how I would get it, or put it on, just simply a list. What do you all think? Am I missing anything vital? Also, this is in addition to what I have already installed.
Garrett
PS What can you do to gain back some of the loss from flywheel to rear wheel?
Vortech SC
Roller Rockers
10# Boost pulley
Auburn Pro LSD
42# Fuel Injectors
70mm TB
3.73:1 Gears
MSD Ignition
hi-perf flywheel
hi amp alternator
electric fans
aluminum driveshaft
anti-roll locker
NOS system
Garrett
Are talking about the boost pulley, or an underdrive pulley? If you mean the boost pulley, I know of a shop that can do custom ones I am contacting them tomorrow to see if they can make one for the vortech No idea about an underdrive pulley. I am pretty sure the gatoryback pulley has been used by someone, just need to verify.
Garrett
Garrett
Check out this article...Im not the most mechanically inclined ****, or the most articulate. Here goes:
http://www.xceedspeed.com/article.php?artid=7
I learned a couple things while reading this.
Garrett
PS Welcome to FTE and all the potential knowledge here
Garrett
Yes, there are power pulleys for our trucks. ASP makes some underdrive pulleys I know for sure...there is an individual who used to be on here who had them on his newer 4.2 as well as rockers and some other mods. I'll see if I can find a site.
Here are some links:
http://www.lmperformance.com/628/4.html
If I were you I would just go to those links and call to see what will fit your truck as far as pulleys go. I'm sure you will get the best answers there. Good luck!
Try this site Jimmy:
www.seffects.com
At the top of the screen just follow the little icons for you year/make/model truck to see what they have that fits.
More specifically:
https://www.ford-trucks.com/framered...w.seffects.com
Good luck
www.seffects.com
More specifically:
Good luck
Yea, I would only recommend pulleys as a last resort. I would definately not get them first. They rob you of drivability whether you want them to or not.
Jimmy:
Get the 17x8's. From personal experience anything over a 17x8 is actually more prone to the outer edge of the rim bending while going over speed bumps, curbes, etc. Plus, IMO they look nicer.
Jimmy:
Hey while were talking about parts that we want, i really want some white faced gauges....but i dont have a tach....every where i look for them they all have the tach and its driving me crazy...ok ok i appolgise i didnt buy a five speed but please please dont deprive me of some cool glowie gauges!!!!!!!!!!!
