Third Brake Light/Cargo Light
Do you have a cargo light in your truck now? if so thats a good starting point.
If not I'd find a '92-'96 and get the light assembly and while you are there make yourself a template so you can install the light into your truck correctly, and yes the wireing harness would be helpful as well, but you might have to get creative with the install into a truck that never had it.
So, the light fixtures are the same & bolt up to the existing area. All that I have to do is change the wiring, correct?
I hate to ruin the party, but I looked into this recently and decided it was not worth the hassle. on 1993-earlier trucks, the opening in the cab for the sincle rear cargo light with brake is about 1 inch high by 4.5 inches Wide cutout there int he cab. the 1994-u cabs witht he cargo/Brake light combo are about a 1 inch by 7 inch wide cutout, so you would have to do soem cutting to get it fit in there. Go pop one off a junked truck and look, you will see what I mean. I was perfectly willing to go run wiring for it, but I draw the line at cutting up a perfectly good cab.
I'm not saying that I'm going to even do it yet. Just trying to get some ideas going on.
This is what my truck currently looks like. I'm hoping to start the construction next week or two.
My 93 F350 crewcab only has a cargo light, the brakelight was added in 94, and the plastic housing will fit, if you notch out the hole in your cab for the extra "stuff" that needs to hang in. Then you connect the additional wire to your brake lights, and it will light up when you hit the brakes.
Its not *that* difficult to do if you really wanted to.
I instead, put inside my clear cargo light, a bunch of high brightness RED led's with a 1.2K ohm resistor for each LED, tied them all in parallel, and wired that up to the brake light switch. I only did this because I had a bunch of LED's around and was too lazy to go to the junkyard when it was 17 degrees outside.
Many ways to skin this cat.
Another option is to take a chrysler minivan tailgate 3rd brake light, theyu are fairly shallow and you can install it with two screws to the sill at the bottom of your rear window. Useless if you have a lot of crap in the bed, or a bed cap, but just because the part doesn't have a ford logo on it doesn't mean it won't work. A 3rd brake light is nothing more than a plastic housing with a light bulb in it. Find one that fits where you want to attach it, and install it!.
If I listed all the non-ford F350 parts I have on my F350 some of you would say I'm not a purist <G>
On my 92 F350 there is only a cargo light. I thought about adding the third brake/cargo light there too, but didnt even think about the cutout size issue. Im thinkin of getting one of the 3-light bars that mount on the back edge of the bed under the tailgate (like on duallies) and putting dual filament tail/stop bulbs in it and running one wire from the tail light wire and one from the stop light wire. Do you think this will work?
Originally posted by stevieray
You will have to enlarge the hole in the cab to fit the newer style brake/cargo lite
I'm cutting the top of cab off the truck anyways when I find a decent one to replace it with.
TexasGuy001
29
12-06-2016 04:00 PM
f-150_1993
39
07-15-2010 10:19 PM
txjason1
06-16-2009 03:56 PM
