What is the difference between F150 and F250?
#31
#32
#33
The mazda was used on the 302s and possibly the 300s but..the ZF was on the bigger engines. I'd only recommend 4.10s if there is a ZF manual being used, or an automatic with overdrive. The reason you guys are getting 9ish mpg is because of the C6 not having overdrive. That totally sucks gas...I have 35s and I just put my 32s on for a lil bit and I went from 2050 rpm to 2240 at 65 and i lost a fair amount in gas mileage. So imagine the difference between 2100 rpm and 3000. lol
#34
Don;t worry, once I'm done my engine/wiring/computer swap I'll get better mileage than even you <grin>.
Well, maybe not at WOT.
#35
phatpharm:
Yes, I understand he has a C6 with no overdrive. carpe_diem agreed, since he has the same setup. I did the calculations, and to be turning that rpm with factory tires (or even 33s) you'd have to have 6.50 gears, and no one would ever have 6.50 gears unless they had 44 inch bogger or 46 inch michlins...
#37
#38
I have the 351. For towing, you will be much happier with a diesel or a 460. I wouldnt want any higher ratio than 4.10 in a 4wd with a 351 unless it was a Bronco or a half ton shortbed. Mine has 3.55 and its a dog. Im planning to go to 4.56 to get more torque for towing. The truck barely gets out of it's own way around town or up hills. It's really embarrassing to be passed on the hills by every gutless 4 cylinder econo box on the road. A 6000 lb truck should never have come from the factory with an engine this small and gears this high. My 33" tires dont make the problem any better iether. Get the bigger engine, you wont be disappointed. If you want better mileage, get one with overdrive or get a diesel.
Sorry, my computer hadnt updated and I didnt see your post about buying the new truck. Looks real nice, hope it serves you well.
justplumducky
04-11-2017 07:43 AM
1984_6.9
07-30-2016 01:07 AM
Iggy1001
04-17-2004 09:38 AM
