What hedders will fit?
I've been putting together a 56 f100 with a 71 302 engine and a c4 auto trans. Of course I had to cut out the original trans mount. Now I need full length hedders. I have a set that fits but they are completely worn out and the identifying numbers I find on them don't help. Surely someone must of had this combination of components before and I would appreciate a make and model of a full length hedder that works.
I have a 1955 F-100 with a 1977 302 V8, C4 automatic, column shift & the Toyota power steering conversion. I am using Blackjack brand headers (Mr. Gasket Company) # 93604. These headers were listed for 1969 to 1979 2wd f-150 with the 302.
Like you said you do have to remove the old frame crossmember.
mwilson, I have about 1 1/2" from the Toyota steering box to the headers at the closest point with the distance increasing with the slope of the gearbox. I used the bolt-in solid bracket, shaped like a '7' , from Mid- 50's. The Toyota gearbox & the old stock box are very similar in size , shape & location if you are trying to judge the available space. Write to me if you need more info.
alf15092
05-27-2015 08:24 PM
gman97005
02-11-2014 01:45 PM
eagle275
11-19-2013 10:18 AM
