89 F150 keeps eating serpentine belts!
I am really getting mad. Last week I had to replace my fan belt because my 300 ate it. Bought a new one for 24 bucks and today I herd it eat it again. Looked under the hood and sure enough it skipped the grooves and the fan ate the front half of my belt and broke my coolant reservore lid. What could be my problem. every thing looks like it is lined up. and it only skipps on the power steering and A/C compresser pullies.
Check your water pump pulley by trying to move your fan front to back when the belt is removed (no tension). I just replaced my water pump because I had plus/minus 1/4" of angular play on the water pump bearings and I destroyed a serp belt in the process. Now the belt chirping and self destruction are gone.
If you changed the water pump, that means you had to remove the pulley and reinstall it on the new pump. I just did the same thing and noticed that the pulley fits tightly on the water pump shaft. I mean that when I tightened the four screws, I had to tighten each one a little at a time, to keep the pulley from getting jambed at an angle before the bolts were all seated and torqued. Double check the pulley, make sure all bolts are in as far as they can go, and the pulley is fully seated against the face of the pump shaft. You may even be stuck an eighth inch off the pump, but not at an angle, did you look behind the pulley to make sure it was flat against the water pump shaft face?
If you did nothing but change the water pump, and the problem didn't exist previously, then keep looking at the water pump pulley.
Of course, no matter what you do to the accessories you have to loosen the tensioner, maybe something odd happened to it just by wrenching it around to remove the original belt.
