Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-05-2004, 06:15 PM
JSRhone JSRhone is offline
JSRhone is starting off with a positive reputation.
F350 SCS steering box
This is my second used power steering box. The pitman arm shaft bushings wear out. I am running 33x12.50x16.5 tires. I have searched for but can not find anything listed regarding an upgraded rebuilt power steering box. I remember reading about one that has bearings in it instead of bushings.
Or are there any other recomendations
Thanks
Joe
__________________
1973 Ranchero GT 351C
1974 F350 140" W/B Super Camper Special
1987 Bronco II
  #2 (permalink)
Old 01-06-2004, 12:51 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
You may just have to look thru every post re steering box. Searching isn't perfect I remember seeing something about one with needle bearings also.
Have you checked the links in my gallery?
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #3 (permalink)
Old 01-06-2004, 01:13 AM
I found the post from the past I was looking for:
Quote:
Originally posted by 66F250LH
Mark,
I highly recommend that you get a steering gear box rebuilt by Red-Head Steering Gears in Seattle, WA (206-364-3333). Rebuilding gear boxes is all they do. They machine in a bearing at the bottom of the housing to support the output shaft. The orginal Ford design did not have anything to support this shaft (a bad design). A new box will cost you a little more than one out of a parts house ($250) but they are worht the extra cost.
Lynn
Thanks Joe
__________________
1987 Bronco II
  #4 (permalink)
Old 01-06-2004, 05:55 AM
Torque1st's Avatar
Posting Legend
WOW! Thanks for digging that out
more search terms for the next guy:
bearing power steering box gearing gear replacement needle bushing steer pitman arm shaft loose upgrade
If you are looking at this post in a search check out this thread:
http://www.ford-trucks.com/forums/sh...hreadid=188972
Their full address is:
900 N 127th St
Seattle, WA 98133
(206) 364-3333
__________________
  #5 (permalink)
Old 12-28-2004, 10:34 PM
CrossCreek CrossCreek is offline
CrossCreek is starting off with a positive reputation.
76 150 4x4 Tire Size
JS,
I also have a 76 F150 4X4 with 33/12:50X15" and not real pleased with handling or wear and tear. What was the original tire size for this vehicle?
Thanks, John
  #6 (permalink)
Old 12-29-2004, 03:37 AM
Torque1st's Avatar
Posting Legend
There are many posts here with OEM tire sizes listed as well as the closest new equivalents.
You can edit your own posts for up to an hour after you make them. You can edit thread titles for 10 minutes.
__________________
  #7 (permalink)
Old 01-02-2005, 05:06 PM
twolls twolls is offline
twolls is starting off with a positive reputation.
Has anyone actually used Red-Head for box mods?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
