Need New Digital Readout computer for Ford F250 Overhead console?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-16-2002, 10:39 AM
WrangleMomma WrangleMomma is offline
WrangleMomma is starting off with a positive reputation.
Hi again! I am running into a brick wall with my overhead console computer. It's on a Ford F250 Lariat. I have tried finding the part online using the part number, and as I'm not sure what the "official" name of the part is...my search has been fruitless. After removing the old part, it became apparent that a component has "burned up", leaving a black mark on the left side of the digital display, and common sense tells me that this is the reason for the inaccurate display of information on the readout. Can anyone help me locate a new part? Salvage yard or new, I DON'T CARE! I'm open to any help at all! By the way, in case it helps, the part number is F81B-25519C44-A. Thanks guys, and my "Beastie" will thank you too if we find a replacement for this "sick" part, and get my "Beastie" back on its feet! Thanks again!
Wranglemomma
Old 09-16-2002, 01:30 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Hi, not sure where you live but you can try this salvage yard in the town I work in. He has a few chopped up Excursions in his yard.
ABC Used auto parts - 1-800-252-8073 Leominster, Mass.
It is part of a huge network of auto parts stores here in MA.
Good luck.
Did you try www.fordpartsonline.com ?
Old 09-17-2002, 04:28 AM
chuckwpb chuckwpb is offline
chuckwpb is starting off with a positive reputation.
I am also curious if a Lariat style overhead console etc could be ordered and added to my 1999 XLT. FMC wants you to invest in the Lariat package, so it might not be easy to order. Anyone have experience with this?
Chuck
1999 F250 SD SC 4x4 V10 XLT
Old 09-17-2002, 11:12 PM
lugnut lugnut is offline
lugnut is starting off with a positive reputation.
There was a thread about this several months back. A guy bought the parts; posted the part#s and everything. He never followed up with how it worked out!?!? Try a search.
mike
Old 09-19-2002, 03:38 PM
Bubzilla Bubzilla is offline
Bubzilla is starting off with a positive reputation.
Wranglemomma
I installed an overhead console in my 2001 F250 SD. The part with the digital display lists for $262.82 here in the SF Bay Area. The part number is YC3Z-25519C44-AAA. Hope this helps. Now all I need to figure out is where the outside air temp sensor and cable connect to under the hood and that part of the console will work too!
Tom
Old 09-19-2002, 05:24 PM
Monsta's Avatar
>Tom
Tom, it will connect to your non-existant ambient air temp sensor. You'll have to pull one off a wrecked truck (hopefully not a frontal collision as they are located on the driver's side, behind the grill and next to the radiator. It is about the size of your thumb and kinda pointy on the top.)
or you'll have to go visit your dealer again...
Old 09-19-2002, 08:16 PM
Idaho Idaho is offline
Idaho is starting off with a positive reputation.
Old 12-12-2007, 12:17 PM
Monsta's Avatar
Holy thread resurrection!!
Old 12-12-2007, 12:57 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Quote:
Originally Posted by SELFHELP777
I found a web site that sells new ones for alot less than ford www.newfordtruckparts.com
hope this helps
Do you know this thread is from 2002.
Wow, Heck of a search.
BTW. Welcome to FTE.
Old 12-12-2007, 01:02 PM
Quote:
Ha, just noticed you posted in that thread.
Old 04-18-2008, 03:59 PM
mighkel's Avatar
mighkel mighkel is offline
mighkel is starting off with a positive reputation.
T.G.f.SEARCH! This old thread just saved me some cabbage!
Old 04-18-2009, 01:54 PM
wog wog is offline
wog is starting off with a positive reputation.
Faulty design, easliy fixed with soldering iron
There appears to be a design problem with this part, F81B-25519C44-A. Mine quit working also. I found the follow guy on ebay that is offering to repairs this for you for $80.
eBay Motors: Ford F250 F81B-25519C44-A Compass Fuel Meter Rebuild (item 280311919367 end time May-10-09 14:19:13 PDT)
Not bad, ...but I figured if he could do it so could I. Upon visual inspection of the circuit card it was almost immediately obvious what the problem was and I had mine fixed in about 30 minutes.
1. remove the module from the cab overhead.
2. turn the module over, and remove the 1 screw in the center of the back side to remove the ciruit card from the housing.
3. look behind the display screen on the circuit card, you will see 7 resistor labeled "680". The problem is that these parts get warm, melt the solder and come loose or fall off. When I looked at mine, 4 of the 7 had partially disconnected from the circuit card.
4. To fix this, fold the display panel forward to get it out of the way, then solder the resistors back down to the circuit card.
5. Use a ohmeter to verify you have them fixed as follows:
There are 4 resistor in parallel across the card, and these should measure about 17 ohms (68.0 divided by 4).
There are 3 resistor in parallell up the right side, and these should measure 22 ohms (68.0 divided by 3).
Old 04-18-2009, 02:03 PM
wog wog is offline
Old 01-31-2010, 02:15 PM
captain my captain captain my captain is offline
captain my captain is starting off with a positive reputation.
WOG you are the man. I am no electronics expert. I look at the circuit card as you described. I needed glasses and a bright light but I saw two resistors that looked burned. I touched solder to each one... and it's working like a charm.
Old 01-31-2010, 10:41 PM
wog wog is offline
Quote:
Wonderful! Glad my post helped someone. Thanks for the feedback.
2003 F250 overhead display issue wsu0702 1999 to 2016 Super Duty 3 02-12-2017 07:04 PM
Calibrating overhead console display ExpySport 1997-2006 Expedition & Navigator 5 04-28-2012 03:51 PM
2002 f250 ambient air sensor and readout. sbegley28 1999 - 2003 7.3L Power Stroke Diesel 2 09-27-2011 09:12 PM
Overhead readout calibration cjspack Excursion - King of SUVs 11 05-27-2006 09:28 AM
Overhead console readouts are dim floorit Electrical Systems/Wiring 2 11-02-2005 10:14 AM
Tags
2000, 250, air, ambient, computer, console, f250, f350, ford, overhead, repair, sd, sensor, superduty, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
