1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Need New Digital Readout computer for Ford F250 Overhead console??
Old 08-13-2012, 03:42 PM
THEDUKE61's Avatar
THEDUKE61
THEDUKE61 is offline
I'M LIKE A COUPLE OF OTHERS ON HERE I AM MISSING ONE RESISTOR I HAVE TWO THAT ARE 680 AND THE OTHERS ARE 620 THE ONE THAT IS MISSING IS SETTING RIGHT NEXT TO A 620 IS THE MOST LIKELY VALUE?
  #62
Old 09-18-2012, 04:25 PM
glamisdave05's Avatar
glamisdave05
glamisdave05 is offline
I was missing one resistor also. I had 5 loose ones as well. I found a company here is San Diego that builds circuit boards and the guy soldered all of the existing ones in, and I bought a $.99 package of resistors at Frye's electronics. He took care of that and did it for $10 during his lunch break. Now it works great. They are little round tube looking resistors with about 1/2" of wire on either end. The guy did a great job on the solder. 1000% better than I could have done. Try that route before you get too much further.
  #63
Old 10-24-2012, 03:01 PM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
I had mine repaired by a shop in my area that fixes guitar amps. They repaired the broken resistor and it worked well for about two years. It is not working again. I am sending it to one of the EBay repair sellers.
I will let you know how it goes I paid $22.00
  #64
Old 07-06-2013, 05:41 PM
J Darin Prulhiere's Avatar
J Darin Prulhiere
J Darin Prulhiere is offline
Overhead digital console for 2004 excursion
I followed the instructions here and it worked great!
20 bucks for a soldering iron and it is fixed.
I took some pictures of the resistors that were loose in case it helps the next guy. They are the rectangular ones with either 620 or 680 on them.
4 horizontal and 3 vertical in this picture. They are next to the red, round component.
The 2nd horizontal one from the left had come loose on one end.
http://i571.photobucket.com/albums/s...g?t=1373149944
I also took a picture from another angle so you can see the LED screen in relation to the resistors in question.
http://i571.photobucket.com/albums/s...g?t=1373149930
Thanks.
Darin
  #65
Old 07-08-2013, 08:12 AM
frhrwa's Avatar
frhrwa
frhrwa is offline
Originally Posted by Bubzilla
Wranglemomma
I installed an overhead console in my 2001 F250 SD. The part with the digital display lists for $262.82 here in the SF Bay Area. The part number is YC3Z-25519C44-AAA. Hope this helps. Now all I need to figure out is where the outside air temp sensor and cable connect to under the hood and that part of the console will work too!
Tom
mine is out on the backside of the front grill, and you may want to move it to where it gets a good shot at outside air without the under hood air affecting it..
  #66
Old 07-08-2013, 08:13 AM
frhrwa's Avatar
frhrwa
frhrwa is offline
Thanks.
Darin
when you solder them in, stand them up to get air on all sides.. they stay much cooler and won't heat up and fall out again..
ruphianh
2017+ Super Duty
04-19-2017 08:45 AM
wsu0702
02-12-2017 07:04 PM
Epitts72F100
10-17-2016 08:09 AM
Beastie
08-12-2015 09:13 PM
norfolknova
30
08-09-2012 03:20 PM
Quick Reply: Need New Digital Readout computer for Ford F250 Overhead console??
