Need New Digital Readout computer for Ford F250 Overhead console?? - Page 4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #46
Old 08-31-2010, 09:15 PM
criticaleye criticaleye is offline
criticaleye is starting off with a positive reputation.
STUGOTS- Thanks Man!
I just wanted to say thanks to Stugots for your help with the resistors I sure appreciate the help! I ended up messing up my board and just ordered a new one but it was an adventure anyway! Thanks again.
  #47
Old 09-08-2010, 08:10 PM
Lake892 Lake892 is offline
Lake892 is starting off with a positive reputation.
Thanks so much for the info... I was about to go junk yard hunting for my 2002 f250. After reading the threads i performed the fix and it is working like a charm... thanks again I saved much money...
  #48
Old 10-22-2010, 04:52 PM
buster3 buster3 is offline
buster3 is starting off with a positive reputation.
F250 Overhead Computer
I tried the fix the display myself but my fingers wouldn't hold steady. I found a place in Florida (Multi Market) who fixed the dang thing in less than a week for about $35. Unless you have the soldering pencil, great eyesight and steady hands, I would send it off and let someone else fix it. The resistors are pretty small.
  #49
Old 11-21-2010, 09:50 PM
brandon101b brandon101b is offline
brandon101b is starting off with a positive reputation.
overhead console
thanks wog i did what you said on sodering the chips mine also had a burnt spot on the coner of it i thought it was burnt up i said what the hell it dont work anyway ill just try to soder it and it worked
  #50
Old 12-01-2010, 08:44 PM
Ratdog Ratdog is offline
Ratdog is starting off with a positive reputation.
clarification
Lots of help so far, thanks, but I have the classic burn mark on the upper left hand corner but I can't find the resistor. is it inside of the plastic display window or on the circuit card?
  #51
Old 12-02-2010, 01:21 PM
1tonner's Avatar
1tonner 1tonner is offline
1tonner is gaining momentum as a positive member of FTE.
Much Appreciated! My clumsy hands fixed mine. Mine was broke when I bought the truck 3 years ago. I figured NO WAY was i spending $200+ on a new unit.Thanks for the info guys.
  #52
Old 12-06-2010, 12:45 PM
Thank you FTE
I read and studied this posting and then replaced the resistors with the wire type resistor and now my display looks better then when I bought the truck. THANK YOU to "all the people" who contributed to this thread.
  #53
Old 12-14-2010, 11:15 AM
mmenzies's Avatar
mmenzies mmenzies is offline
mmenzies is starting off with a positive reputation.
I used these guys last week
Ford Truck Parts - Full Warranty On All Ford Truck Parts
They fixed it the same day that they received it and shipped it back out the next. $29 plus shipping which is pretty reasonable.
They were really nice and efficient and easy to work with, so by the time you have found the resistors at Radio Shack and messed around with a shaky hand on the soldering iron you just may be better to shell out the $29 and let the experts do it for you.
Mark
  #54
Old 12-17-2010, 02:05 AM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
Mark
I have an Excursion (see my sig). What is the procedure for remmoving the overhead console so I can remove the "guts" and send in for repair?
Did you have written instructions or did you just "dig in" and slowly start removing screws? Are their instructions somewhere on the net?
Came across the site you posted above, but was curious about them and/or their work?
Thanks,
Thanks,
  #55
Old 12-17-2010, 11:20 AM
mmenzies's Avatar
There are four metal snaps one in each corner. Slide your finger under the left rear side first and start to apply pressure. When it pops you will think damn I broke it but it probbaly isnt broken. Next go to right rear and do same and then again front right and left.
Unplug the unit. I sent in the whole unit but if you want to reduce the shipping cost remove the 4 torq screws and juts send in the black display part.
Mark
  #56
Old 01-30-2012, 10:48 AM
Gort Gort is offline
Gort is starting off with a positive reputation.
hi guys. I want to fix mine but I can't figure out how to get it out. Is there a clip or something holding it? I don't want to break! can you give me some help? I've got an 04 350
  #57
Old 01-30-2012, 11:31 AM
mmenzies's Avatar
Gort
read my post above yours its pretty self explanitory.
Mark
  #58
Old 01-30-2012, 12:15 PM
Just did mine. it works great. I didn't have any burned contacts but when I tested them with my pocket knife I found a few that were loose. thanks to mmenzies.
  #59
Old 05-01-2012, 02:06 PM
microdevil45's Avatar
microdevil45 microdevil45 is offline
microdevil45 is gaining momentum as a positive member of FTE.
Going to do this later.
  #60
Old 05-02-2012, 10:03 PM
Thanks for the directions wog it worked exactly great. I think I will refer to this as the "wog mod" if you don't mind...
Explorer overhead console install norfolknova 1987 - 1996 F150 & Larger F-Series Trucks 30 08-09-2012 04:20 PM
2002 f250 ambient air sensor and readout. sbegley28 1999 - 2003 7.3L Power Stroke Diesel 2 09-27-2011 10:12 PM
overhead console digital readout faulty? 3504x4 1999 to 2016 Super Duty 19 06-22-2010 02:06 AM
Overhead readout calibration cjspack Excursion - King of SUVs 11 05-27-2006 10:28 AM
Aftermarket Digital Trip Computer BigMattXXL Expedition & Navigator 10 09-16-2005 01:08 AM
Tags
2000, 250, air, ambient, computer, console, f250, f350, ford, overhead, repair, sd, sensor, superduty, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
