Windshield Wipers - Page 2 - Ford Truck Enthusiasts Forums
Windshield Wipers
Old 01-10-2004, 03:08 PM
chasparham's Avatar
chasparham chasparham is offline
chasparham is starting off with a positive reputation.
I use STP Vision Blade on all my windshields. I like it better than Aquapel. The rain flies off so good you don't need the wipers if going around 45-50 MPH. It also makes ice and snow MUCH easier to remove. You can't buy it any more but as usual you can find almost anything on Ebay.
Old 10-21-2009, 11:11 PM
jr105 jr105 is online now
jr105 is gaining momentum as a positive member of FTE.
There were quite a few posts about this when the 04s came out, and removing the key and repositioning the arm was the most common fix. One other fix that was mentioned and I tried, was to swap the passenger and driver side arms. Apparently they were slightly different on the 04. It gained me about 3/4" to 1" of sweep. I don't know if this will still work on newer trucks.
Old 10-24-2009, 11:07 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4 2004 xlt 5.4 is offline
2004 xlt 5.4 is starting off with a positive reputation.
Quote:
Originally Posted by 1955ford View Post
I removed the driver side wiper arm , and used a soft cloth to cover the portion where the small arm is swedged into the portion that attaches to the spindle . Then placed arm in shop vise , and slightly "straightened" arm a small amount. It now "rests" almost horizontal on the windshield , the end now divides the small ford logo on lower center of glass. This makes the wipe to the left about 2 inches greater. wiper also looks better at rest.
Did this yesterday works great and so easy to bend I'm near the top of logo there is no ill effect to the wiper function even at highway speed
Old 10-25-2009, 01:09 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
wow...haven't seen this thread in a long long time.
funny, but I never noticed an issue with snow when I lived in Seattle. Guess it's only a problem for you heavy snow drift guys.
@ 2004 XLT
how hard was it to remove that spline key? I run 26 & 24" blades on my Expy and it would be nice if there was more sweep to the thing. I ran 24" blades on my 2006 FX4 and they had a pretty good pattern, but I've found 26" is just a tiny bit better
Old 10-25-2009, 08:56 AM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Quote:
Originally Posted by Opahujo View Post
To: fanman2 and Lariatf150
Also, I have on occasion not shut the wipers off before turning the ignition off. Then, when I started up later, the wipers were frozen to the windshield. It's sort of a helpless, teeth clenching, situation because even if you turn them off, those wipers try to go to the "home" position. When that happens, you can see the wiper arms strain, but none has ever broken off.
Opahujo in Iowa
During the first of 10 years in Germany I learned to lift the wiper arms up off of the windshield when I parked the vehicle when snow is expected. It takes only a few seconds. That is a lot less time than standing there trying to free the wipers from the ice the next morning. To get going the next time I would let the vehicle warm and defrost the windshield then flop the wipers back down after scrapping the glass clear.
Old 10-25-2009, 11:33 AM
@ 2004 XLT
Not hard when I pulled it off it was still in the L shape at the spring end I hit it by accident on table and spring snapped straight and the key fell out on its own.
I wanted the key I glued it back in.
Bent the arm instead and is great now comes to 1 1/2 " from top of pillar.
And no worry about stripping the fine splines.
As we tend to get lots of snow and drive in storms snow build at end of wiper stroke could stress the splines they look to be finer than the old ones that had no key ways.
So yes easy to get them out.
Old 10-25-2009, 03:04 PM
Tylus's Avatar
thank you. maybe I'll play with it
Old 10-26-2009, 10:32 PM
JoSHN JoSHN is offline
JoSHN is starting off with a positive reputation.
If it wasn't so streaky when you use the wipers, Rain-X did wonders to remove snow and ice. It took 1/3 of the effort to scrape ice off the windshield.
I earned this after putting some Rain-X on my windshield before we got into or rainy season only to get struck by a freak snow/ice storm. Below freezing temperatures and a foot of snow over night. Everything was covered..... except for my windshield.
But, as I stated before, if you use the wipers with the rain-x it leaves a blinding streak across the windshield which lasts for a few seconds.
Old 10-27-2009, 09:29 AM
I have found that nearly all will windows streak on all cars especialy after the windows gone through a winter on the hi way and gets some pitting
Have used Rain -X for 14 years and it has less smear for me than if not treated
wont go without
That's just me.
Windsield Wiper Assy. Problems F150III 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 12-28-2013 10:20 PM
Windshield Wiper Problem Vegas Ernie 1997-2006 Expedition & Navigator 3 03-29-2008 07:08 PM
Windshield Wiper Arm Pivot Assembly mantta 1987 - 1996 F150 & Larger F-Series Trucks 3 05-21-2007 11:42 AM
Left turn - no windshield wipers evan250 1968-2013 Full Size Vans 1 09-12-2004 10:01 AM
2004 F-150 Defroster Opahujo 2004 - 2008 F150 13 02-11-2004 09:45 PM
Tags
2000, 2004, arm, expedition, f150, ford, position, put, rear, remove, resting, snowice, windshield, windshields, wiper, wipers, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
