Lowering a f100
Any of the straight axle gang want to take this one? They always get suspicious when the IFS characters here tell them 6 inches of drop causes huge compromise in drivability with a stock suspension. You'll have "issues", and lots of them. Poor ride, handling, geometry, spring wrap when braking.
Best way tp drop with a S.A. is a drop axle, and the correct tie rod ends etc for the mod. But that won't get you six.
It is common to get about 3 inches from a drop axle. Then you can experiment around with minor (reversible) mods like pulling a leaf from the pack etc. Until you find the line where you say, "my truck now sucks to drive". Then just reverse the last baby step you took that screwed up your truck. Or you can try soming radical like the latest mono leaf spring. You'll be sitting in Alaska with a 400 spring you hate. Forced to try to make it work. Drop axle is time tested. The grief cause by one are minor compared to screwing up your springs.
juchertf100
33
03-06-2016 12:59 PM
