4.6 timing chain setup. - Ford Truck Enthusiasts Forums
Old 01-04-2004, 07:17 PM
johnnypi johnnypi is offline
johnnypi is starting off with a positive reputation.
Cool 4.6 timing chain setup.
When installing timing chains on a 4.6 sohc, Do you install both chains at the same time or do you start a separate setup for each cam? This is my frist time doing this type of motor. i'm having trouble lineing them up. every time i put the chains on together left side is hitting the pistons while i turn with a breaker bar and socket
Performer cam/Cloyes timing chain free59mod FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 11-23-2015 11:29 PM
Timing chain scorpion58 1997 - 2003 F150 2 06-13-2015 11:13 AM
4.6 Timing chain rattle on hot restart mlhebel Modular V8 (4.6L, 5.4L) 10 02-18-2015 09:37 AM
Timing chain and gears jayron 1997 - 2003 F150 0 03-30-2014 11:49 PM
1997 f150 4.6 liter timing chain kenrobert 1997 - 2003 F150 6 03-08-2004 01:46 PM
Tags
46, 46timing, chain, diagram, f150, ford, gear, install, motor, nascar, setup, sohc, timeing, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
