96 explorer O/D light blinking???? - Ford Truck Enthusiasts Forums
Old 01-04-2004, 10:53 AM
kodeman05 kodeman05 is offline
kodeman05 is starting off with a positive reputation.
i was on my wy tho the store the other night and i noticed that my O/D light in the bottom right corner of my dash panel was blinking. it had me worried for a while because i have never seen it before and i thought that something was wrong with my truck. if you could please tell me what that means i woul appreciate it. THANKS!!
Old 01-05-2004, 06:09 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
It means the computer thinks that your OD is not working properly. You should also notice that the trans is shifting a bit harder, which it not good for the trans. I suggest pulling the codes to see what they indicate. Also, it may help to disconnect the battery for 5 minutes to clear the codes. If the light comes back on, you definitely have a problem.
Old 01-12-2004, 04:26 AM
Dayle Dayle is offline
Dayle is starting off with a positive reputation.
If I am not mistaken the o/d light will blink in a pattern to let you know what is wrong.
Old 01-12-2004, 07:22 AM
Sweet012 Sweet012 is offline
Sweet012 is starting off with a positive reputation.
I've had this problem twice on my 95 Explorer and the first time I took it to a shop and after $180.00 which included change of filter and new trani oil, mechanic did pull the codes but was unable to figure out what was wrong. So, he disconnected the battery for about 5 minutes and everything was back to normal. One good point from Dayle is that when this happens you trani starts shifting harder which can lead to more serious problems. About a week ago after almost 1 year it did it again. This time I went ahead and remove the battery cables for about 5 minutes and truck is working fine. I figure if it happens a third time, then I will for sure take it in again for a checkup. Hope this info. works. Good Luck!!!
Old 01-12-2004, 08:21 AM
mason mason is offline
mason is starting off with a positive reputation.
I also have a '95. In the five years that I've owned it the O/D light has started flashing 3 or 4 times. Each time the light after resetting stays off for another 6 to 18 months. I'm not too worried about it since it doesn't come on back on immediately, indicating a more serious problem.
Mason
Old 08-12-2007, 11:58 PM
MS FORD X95 MS FORD X95 is offline
MS FORD X95 is starting off with a positive reputation.
Thanks to you all and I will try the 5 minute battery disconnect.
Speedometer not working and O/D light blinking Polkster 1999 - 2003 7.3L Power Stroke Diesel 7 06-28-2015 06:57 AM
O/D light blinking associated with high RPM's and hard shifting! (NEED HELP) deepbass 1978 - 1996 Big Bronco 8 07-29-2006 08:51 AM
ABS Light on and now OD light blinking bmwfirearms 1999 - 2003 7.3L Power Stroke Diesel 16 10-15-2004 03:43 AM
Overdrive light blinks when overdrive is off NascarNut 1978 - 1996 Big Bronco 5 07-09-2004 12:00 PM
blinking O.D. light keepkoolac 1999 to 2016 Super Duty 14 05-23-2004 10:33 AM
Tags
1996, 88, 95, 96, blink, blinking, codes, explorer, flashes, flashing, ford, light, od, overdrive, randomly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
