rotors and brakes (truck shakes when braking)
Old 01-04-2004, 06:59 AM
GMUZZY95's Avatar
GMUZZY95
GMUZZY95 is offline
Need help changing my rotors on '95 F-150 4X4 truck really shakes when braking..never worked on brakes before ..want to remove and replace front rotors and adjust rear brakes..pics and description would be helpful have tools just need direction
Old 01-04-2004, 10:40 AM
pmadtaylor's Avatar
pmadtaylor
pmadtaylor is offline
Sounds like a warped rotor. Just had my front rotors replaced as the drivers side was badly warped, but had a mechanic do it since I didn't have the special tool to remove the hubs. A Haynes, Chilton or Ford repair manual can guide you through the process. If you are leary of doing it yourself, find a local mechanic. My rotor replacement only cost $80.
You will also want to check your universals in the front. Mine were bad.
