351 vs 350 - Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
351 vs 350
Old 01-04-2004, 02:17 AM
640 CI Aluminum FORD 640 CI Aluminum FORD is offline
640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.
351 vs 350
Witch is a better engin Ford 351 or Chevy 350 I belive the numbers for the 351 EFI are 210 and 335 and the 350 is 200 and 315 Witch one is faster witch pulls harder [has more power] witch will tow better. Its been along time since ive driven a 351 I remember it as a pretty powrful engin as a company truck Im stuck with a 1993 Chevy 1500 with a 350 its an ok truck but the reason Im asking why is becus I have a chance to buy a 1996 F-150 Extended Cab with a 351 and only 15,000 miles it cost $10,000 What are your personal Experinces with both engins. I know thay both have alot running for them but im just curious......
__________________________________________________ __
1997 F-350 460 Extended Cab 460 CI V8 C6 auto
Hopefully an 1996 F-150 351 4R70 4speed auto
Ohh ya and witch Gets Better MPG
Old 01-04-2004, 06:30 AM
clean79150 clean79150 is offline
clean79150 is starting off with a positive reputation.
I don't have any stock numbers to give you, but a recent issue of , I think it was, Car Craft magazine did a low budget rebuild which included a Chevy 350 and a Ford 351W. Unfortunatly with the same budget for the rebuilds the Chevy yielded a good bit more Hp and Torque than the 351W.
Old 01-04-2004, 07:50 AM
RTM RTM is offline
RTM is starting off with a positive reputation.
About a year ago on a mustang site I visit daily there was a new memeber that started up a topic on which motor was better, the 351W or the 350 chevy. I know your looking for numbers but I thought I would share this. He was looking for engineering reasons why one would be better than the other.
It turns out the 351W is a better design. He was a writer from a boat magazine and was writing an article on the two motors. He also admitted that he was a chevy man but the ford motor was better. I wish I had the article.
Old 01-04-2004, 10:32 AM
c_rossman c_rossman is offline
c_rossman is starting off with a positive reputation.
351W is better built with larger main and rod bearings. It also has a taller deck hieght which will help it live longer. Also if you ever notice the chevy heads have two exhaust valves right next to each other in the center of the head E-I-I-E-E-I-I-E, where as the all fords go I-E-I-E-I-E-I-E. The heat is better distributed thru the Ford Heads than Chevy Heads.
Old 01-04-2004, 12:42 PM
RTM RTM is offline
You got it and I think the distributor is one as well. The timing is more accurate in the 351W than a 350 chevy due to the fact that the cam shaft twist from one end to the other.
I think there where a few other things but I can't recall.
Old 01-04-2004, 01:26 PM
F150daniel F150daniel is offline
F150daniel is starting off with a positive reputation.
the 351W has a better rod ratio
351W 1.7
350 1.63
Old 01-04-2004, 01:28 PM
fordman428's Avatar
fordman428 fordman428 is offline
fordman428 is starting off with a positive reputation.
one other thing thats better about tuning your engine and etc.. about the 351 the distributor is in front "easy to get at" unlike the 350's distributor is in the back and hard to get at and work on, just my tohught on a little better design from ford.
Old 01-04-2004, 03:09 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
It really depends on the application. I have a 351w in my van. It's got 152k miles and still pulls hard. Treat them right they'll last a long time.
Old 01-04-2004, 08:24 PM
jj292's Avatar
jj292 jj292 is offline
jj292 is starting off with a positive reputation.
Ford definatly has the better design, engineering wise I just wished they did like chev and not have so much variation in the different engine 351w, 351c, 351m - windsor, 385 series, y-block, modified, FE...
Right or wrong the fact that parts from a 350 will fit a 454 has helped push the chevy into the head of aftermarket engine building.
Old 01-04-2004, 08:52 PM
Saurian's Avatar
Saurian Saurian is offline
Saurian has a good reputation on FTE.Saurian has a good reputation on FTE.
I would jump for the 96 just because its newer, Ext Cab, and all that. However, what are you going to do? If you're going to leave it stock, the Ford would be better. If you have a very limited budget to mod with...your current vehicle may be better to keep and mod. If you expect to mod and mod alot, you can extract more power from a 351...but again with more money involved. Also the 351 has better design as mentioned. I'd say Go for the Ford if it is reasonable.
Every time at work the register says 3.51 I concider it a good omen . Even got a few 4.60 and 4.27's runing around too...
Old 01-05-2004, 01:27 PM
Lectrocuted Lectrocuted is online now
Lectrocuted is starting off with a positive reputation.
I'd have to say they're about equal. 1/2" of deck height doesn't really matter. Either can be built n/a to send a modular scampering home.
Old 01-05-2004, 04:44 PM
gamehunter gamehunter is offline
gamehunter is starting off with a positive reputation.
LOLLOLLOLLOL
your on a FORD site, what kind of an answer do you expect to get?
btw, both engines had 210HP but the ford had the chevy beat slightly in torque, 315-325 Ford vs 310 chevy. This is comparing Fords mid 90's EFI to Chevy mid 90's TBI. They both are good engines. As far as a camshaft twisting and throwing off timing......there is alot more to timing than that.
Old 01-05-2004, 06:15 PM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
Cam twist only becomes a problem on 350s making very big HP numbers. Cams have been known to break on rare occasions though.
Old 01-07-2004, 09:58 AM
grizz5675 grizz5675 is offline
grizz5675 is starting off with a positive reputation.
Alot of problems ive seen from the 350 and the 351 stem from no prevenative maintainance. They are both great motors if you take care of them.
Old 03-10-2004, 03:18 PM
teenagegearhead06 teenagegearhead06 is offline
teenagegearhead06 is starting off with a positive reputation.
I have a 95' F-150 with a 351 and a 93' chevy 1500 with a 350 and it seems like the ford has more low end torque than the chev but at higher rpms the chevy is faster.
transmission help. HotRodRob 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-14-2013 03:38 PM
4spd vs c6 79fordf250pickup 1973 - 1979 F-100 & Larger F-Series Trucks 19 03-07-2012 02:31 AM
F250 lift. Questions letsdothis 1973 - 1979 F-100 & Larger F-Series Trucks 14 04-26-2011 01:48 PM
NEED HELP deciding on an engine!!! thefordlane 1973 - 1979 F-100 & Larger F-Series Trucks 34 04-03-2010 02:17 PM
79 460 oil pan leak ford-man 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-14-2007 10:23 PM
Tags
251, 350, 351, 351c, 351w, 93, block, chevy, compare, eiieeiie, f250, ford, forum, timing, vs, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
