Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 01-02-2004, 07:18 AM
fitter565's Avatar
fitter565 is starting off with a positive reputation.
Question Throttle body spacers Do they work?
Hey everyone, I want to install a TB spacer on my 04 F250 5.4L 4x4. I was wondering if anyone has installed one of these and do they work?? I can't find one for an 04 but they list one for an 02, are the TB'S the same on these two years? Thanks in advance for your help.
Fitter
__________________
2005 Explorer Sport Trac XLT Premium
2002 Escape XLT 4x4 3.0 v6 (Wifes ride)
Support FTE
  #2 (permalink)
Old 01-24-2004, 08:47 PM
94F150-408 is starting off with a positive reputation.
Hey Fitter,
I've used one on a dodge 2001 5.8 and I dident notice any difference at all. Save your money, you'll get alot more out of exhaust work, intake, electric fans or for the real bang...supercharge it!
__________________
94 F150 4x4 393 Stroker
95 Bronco- 408 SuperCharged
Mods in Gallery
  #3 (permalink)
Old 01-24-2004, 10:58 PM
94Bronco58's Avatar
94Bronco58 is starting off with a positive reputation.
The reason they don't work on our trucks is the reason the only time they kick in is at high RPM's like 5000-6000, much higher than we run under normal conditions, I thought about getting one for my Bronco, but read on the Bronco chapter that they only work at high RPM, and the highest I have had mine is a little under 4000, so thats $100 saved!!
__________________
1994 Bronco 5.8 and some mods!
  #4 (permalink)
Old 03-08-2004, 04:12 PM
claynewt is starting off with a positive reputation.
Fitter,
I just put an Airraid on my 5.4 F150 FX4. I'm noticing a strange whistling sound at diff rpms. Checked all connections for a leak but found none. Salesman said it might do this because of "vortex". I don't know for sure. Seems like it might have helped @WOT.
__________________
2003 F150 FX4 Lariat, 5.4l 3.55LS
  #5 (permalink)
Old 03-08-2004, 07:19 PM
triton_2002's Avatar
triton_2002 is starting off with a positive reputation.
You will get a intake suction sound (whistling) with a TBS, but I like the sound of it. I put on an Airraid intake and TBS on my F150, can't say that it gained X amound of HP, but I didn't hurt anything either.
__________________
2002 F-150 Supercab 5.4 Triton V8
Arizona Biege
  #6 (permalink)
Old 03-08-2004, 07:27 PM
triton...yeah, I dident notice any difference either, except you said it dident hurt anything....except our wallets if we dident gain any HP!
__________________
Mods in Gallery
  #7 (permalink)
Old 03-08-2004, 08:51 PM
I didn't say I didn't notice any differnce, but I just don't have any figures to back it up. I put the intake, TBS and Borla muffler on at the same time so I can't say which was better. But it was a good combination and did improve performance IMO.
__________________
Arizona Biege
  #8 (permalink)
Old 03-08-2004, 09:56 PM
triton, that intake pipe you put on looks pretty good, I"m sure between that and the Borla you made some improvement!
__________________
Mods in Gallery
  #9 (permalink)
Old 03-09-2004, 11:13 AM
Triton- I don't mind the sound that much, just a little disconcerting to hear what sounds like a dirt gathering vacuum leak.
Soemething else.......we had the first cold night since I installed the TBS and my motor woundn't fire this morning. I finally pumped the a couple of times then it started with some smoke from the tailpipe. Hope it was gas! Truck only has 4750 miles on it.
Has anybody heard of this before? I thought fuel injection should eliminate slow starts.
CONCERNED!!!!
Thanks .......
__________________
  #10 (permalink)
Old 03-09-2004, 03:51 PM
Yeah, I've heard that larger intakes and/or TBS may cause some hard starts in cold weather, but I don't have to worry about that in South Texas.
__________________
Arizona Biege
  #11 (permalink)
Old 03-09-2004, 11:43 PM
The biggest problem with any sort of "whistling" noise... that is generally assosiated with turbulance, which doesnt equate to increased HP when that turbulance is anywhere in your intake/ports of your vehicle.
__________________
Mods in Gallery
  #12 (permalink)
Old 03-13-2004, 08:29 AM
lariatbob's Avatar
lariatbob is starting off with a positive reputation.
BTW claynewt- fuel injection has a cold start enrichment which adds more fuel for cold starts. If you continue to have cold start probs, have it checked out. There is no acceleration pump "squirter" like on a carb, so pumping doesn't do a thing (thats why you can't "flood" it by "pumping") Just FYI
__________________
2000 F-250 Crew Cab PSD
4" Turbo back, Magna Flow Muffler
4"spring lift, ART Rotors
Killer Metal, Wicked Wheel
HPX-hose, Sonnax/Tricumulator kit.
Oil Guard filter
http://www.bobcolley.com/truck.html
  #13 (permalink)
Old 03-13-2004, 08:55 AM
forddytube's Avatar
forddytube is starting off with a positive reputation.
iv'e heard that although the power commes at higher rpm it is something that creates a bigger gap(1")or (2") improving gas milage and cooling the air and mostly it's something that would benefit a towing truck for torque more than hp.
did you guys notice better throtle response? thats one of the other things it deffinately helps,
__________________
91 F150 xlt
69 Torino Coupe
53 Ranch Wagon
  #14 (permalink)
Old 03-20-2004, 12:47 PM
Muskegdon is starting off with a positive reputation.
I was disappointed with the so called power advantages of the spacer until I started pulling my trailer. There was a noticablable increase in performance on hills when I had to kick down to climb. And I think it is one of the bigger contributors to my none pulling fuel ecomomy. It is usually the combination of alot of little improvements that make the big noticeable difference in power.
  #15 (permalink)
Old 03-20-2004, 12:57 PM
Nate1040 is starting off with a positive reputation.
Muskedon I too did the throttle body spacer. I think I noticed a difference. The I went for the whole enchilada and did most all of the bolt ons.
Last October I drove to Las Vegas, 75 mph cruise control, and averaged 18.6 mpg. When I bumped it up to 80 in the hilly parts of the trip my mileage went down to 16 something.
I think the throttle body spacer is just one piece of the puzzle. I agree with you that the combination of bolt ons gets you the noticable difference.
__________________
'02 F150 7700, Banks headers & cat back. Flex-a-lite Monster Fans. Kenne Bell Supercharger. Needs new rear tires!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
