How To Wire My 302?
How To Wire My 302?
could someone please tell me how to wire my starter up on my 302. is there only one wire? i know there was a black ground wire. also whats the best way to wire my engine to start it up with the cab and bed off. do i have ti use the ignition switch in the cab or can i use something else. i have a performance distribtors duraspark ignition and distributor. on the wiring diagram it shows a resistor between the ignition switch and the coil. would this be the little 2-3 inch long brass piece with a connector on each end. where exactly do i attach the ground wire from the battery to. i believe the ground for starter was on attached on top of engine.i also have a powermaster one wire alternator does the one wire connect directly to my positive battery post.im really at a loss on all this. the shop i had my truck at went out of business and called me to come get it and said they couldnt complete it. so i went and picked it up all 500 dismantled pieces of it so now im trying to get it back together but am unsure about the proper wiring because i wasnt there to watch when they took it apart.thanks for any help you guys can give me.
Here's the basic heavy wiring for the starter.
Here's a link to the basic ignition wiring if you want to rig it up. I would think you could run it for a couple of minutes without the resistor. Or buy one of those resistors for a chrysler and rig it in the circuit. The original resistor is buried in the truck wiring harness.
