LOUD, strange clicking/rattleing noise coming from under my truck.
Its a very loud, very strange noise. It doesn't click in the morning or after a long time sitting, its just when it warms up, that it will click. It also seems to click in rythm with the tire rotations. As I start rolling faster and faster, it starts clicking faster and faster, and get this, as soon as ANY brake pressure is applied, it stops (i can drive around town with the brake pedale slightly depressed and it makes no noise). At this point it would seem like the brakes, but heres where i get lost, i've gone over my brakes a half dozen times and haven't seen anything that would be making this noise! I've replaced the front disks, pads and calipers (coincedence), and i've also replaced the star adjusters, adjusting cables, and new shoes on the rear drums( the drums themselves were still good). Also the fact that you can here it rattle when i hit a bump. Theres only a few things I can think of, and thats the rear end (very worn, ready for a rebuild) or a warped drum. Before i waste anymore money, I hope someone else could give me some help
Worn slider pins on the front disk brakes will cause the caliper to move excessively. when there is no brake pressure applied, the pads will sometimes click or rattle. all rotors have runout to some degree. The pads will rub on the high spot on the rotor and click in tune to the rotation of the wheel. The noise will stop to the slightest pressure applied to the brake.
Two pennies.
Dan
Two pennies.
Dan
I've been wondering this, what is up with the "ABS" on these years, because my brakes will lock up without a problem, and yet I have an anti-lock brakes light on my dash.... Also, is this sound really that loud, I have a clicking/rattling comming from undernearth but I'm fairly sure it's my tranny gears. Is it an auto or manual?
did you make sure to readjust your parking brakes ? sounds like they are out of adjust ment and when the brakes heat up, they are contacting it. then as you apply brakes, it takes away noise because everything tightens up. out of round drums would sorta pulse like warped rotors. and you should check for lateral runout on front rotors if you feel a normal pulse and you changed all the front components.
pat420swed
24
07-03-2016 09:20 AM
John90
1997 - 2003 F150
26
10-02-2012 02:35 PM
jck_strw
11-18-2008 12:02 AM
4.0 Beast
03-01-2006 12:19 PM
