Thumping noise from front but stops on braking - Ford Truck Enthusiasts Forums
Old 11-17-2014, 08:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
Old 01-01-2004, 07:53 AM
Snaderi Snaderi is offline
Snaderi is starting off with a positive reputation.
Hello again to everyone
I have a 99 Ford Explorer XLY 4WD auto. I have noticed a thumping sound from the left side of the car. The noise is there almost at any speed, but at higher speeds it disappears or I just can't hear it any more. But when I put on the brake it disappears, or when I turn either left or right it disappears. The noise is most evident when goin abot 5-10 MPH.
The brakes look good and the tireslook good too. I thought it might be a flat spot on one of the tires.
Any help would be appreciated.
Old 05-29-2004, 03:09 PM
tcguertin tcguertin is offline
tcguertin is starting off with a positive reputation.
Noise
Good luck, I have been looking for 5 years to get rid of my noise.
Old 05-29-2004, 06:05 PM
LV Dan LV Dan is offline
LV Dan is starting off with a positive reputation.
Thumping, too.
I have a 99 XLT 4x4 that has a slight thump in the front drive train, too. Brakes look good, tires good. But I can't seem to pin the problem down to a speed or part. Checked my differential fluid today-its just fine. Thought it could be a CV joint, but it does not get louder in 4wd. I would think the drive power would make it worse. It could be that the hubs are locking in, but I don't know how I could tell if they are locked or not. Since "tc" has had the problem for 5 years, I will not tear anything down until it gets worse.
Dan
Old 05-30-2004, 10:16 AM
daerhldgs2 daerhldgs2 is offline
daerhldgs2 is starting off with a positive reputation.
A thump that stops when the brakes are applied is normally from a pad that moves up and down or a loose caliper . It could also be a separation in one of the front tires, try rotating them to the rear.
Old 06-05-2004, 10:30 PM
PirateFins PirateFins is offline
PirateFins is starting off with a positive reputation.
I have had the same problem for 5 yrs also. What tires are you running? Mine did it, I replaced the tires and it went away for about a year and then the noise started back up. I have the wrangler rts on there now but I'm going to change to Revo's soon. Check you alignment also, my truck has way to much neg camber and the inside edge of the tires is really worn. I really think it has something to do witht he tires being that it went away for a year after I put a new set on.
Old 06-07-2004, 04:02 PM
I'm running Goodyears also, replacements for the Firestone recall. Ironically, my Firestones did not show signs of problems, but the dealer replaced them anyway and then one new Goodyear tire seperated while on a road trip--less than a 1000 miles on them. But the dealer wouldn't replace the Goodyear tire. I felt a strong pull to the left (front driver side tire) which told me something was wrong. Then it started to thump loud.
My Goodyears are getting old and slightly cracking so it is possible that it has started to seperate. I have never rotated the tires and they have worn very evenly side to side and front to back. Here in Las Vegas, I usually have to replaced tires because they dry out before I wear all the rubber off.
I will try moving the tires around and see if the sound follows.
Old 06-07-2004, 04:26 PM
Thumbing Noise
Try swapping the rotors and see if that don't take care of the problem.
Yes, it sounds strange, but if work for me.
Old 06-07-2004, 04:28 PM
Thumping Noise
I final repaired what four dealers could not repair. The noise in my front end was being created by the AWD transfer case. After installing a junk yard transfer yesterday and testing it last night, the noise is gone. The dealer work on it for the past 5 years and charged my extended warranty over $8,000 to not repair the noise. After getting a refund from the last dealer I decided the noise could only be in the transfer case. I located a transfer case in Traverse City, MI with only 46,000 for $400. That was a fair deal, especially since it solve my noise problem.
Thanks for responding Tom Guertin
Old 08-20-2004, 11:45 PM
Msp541 Msp541 is offline
Msp541 is starting off with a positive reputation.
I have the same noise on my truck now i have a 99 mountaineer awd and replaced the transfer case in it last year due to a HUM sound on the highway, so now i have that thumping sound coming from the LEFT DRIVERS SIDE at a speed of 15-40 mph then i cant hear it, i have replaced the ball joints, stabalizer bar bushings, and front brakes and pads, the only other thing i could think of would be CV Joints or Wheel Bearings or possibly the rotors? Im stunned and im waiting for it to get louder to figure this stupid problem out!
Thump thump thump while turning -- sounds like ujoints Rays auto 1999 to 2016 Super Duty 1 09-06-2016 11:49 PM
Steering/Suspension Noise, Goes Away When Braking Da_Lariat_Chariot 1987 - 1996 F150 & Larger F-Series Trucks 2 08-16-2015 10:40 AM
'85 f-250 4x4 left front wheel or hub noise Abzack 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 12-01-2009 02:36 PM
Squealing coming from Wheels or somewhere under chassis Budderamos 1997 - 2003 F150 24 09-16-2008 07:33 PM
thump thump scar98 Clutch, Transmission, Differential, Axle & Transfer Case 7 10-31-2005 10:21 AM
Tags
awd, brakeing, braking, bronco, dissapears, driver, ford, front, mountaineer, noise, rear, side, sound, thumping, thumps, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
