SD SC Rear Door Panel Removal
After sliding into a tree in the mud... I got to do this to pop out the dents. There are two pieces to the SC door. BE careful when following these instructions cuz I am going from memory. The good news is that I did not have a hard time figureing out how to do this.
1.) Remove the two screws that hold the window squeeze hinge to the door
2.) Pop the top section off carefully
3.) as I remember a screw/bolt that holds the bottom section to the door. There may be 2 so ck carfully.
4.) Remove those bolts
5.) pop off/lift up the lower section
6.) viola!
Took me about 2 minutes total, even with figuring it out. I found a tape covered screwdriver helpful for the operation.
99 F250SD EC 5.4L 3.73 285 BFG/ATs...
99 Expy EB 5.4L
6.) viola!
99 Expy EB 5.4L
