stock turbo rebuild (anything else!)
I just ordered the stock 7.3 powerstroke turbo rebuild kit from Clay and was wondering if I am rebuilding it should I upgrade anything. My truck is stock and really dont want to spend a bunch of money on upgrades. But already having the turbo out and rebuilding it,does it make sence to upgrade.and what advantage will i get.Thanks
The E99/'wicked wheel' moves less air than a stock compressor wheel. This can help with turbo surge, but it is unlikely you'd have this on a 'stock' truck.
You can use VHT 'flame proof' on the exhaust housing for a DIY ceramic coating. We've used this on up-pipes too. I'm not sure it makes as big of a performance difference as some flashy racing stickers, but it makes under the hood look good!
Available at your favorite autoparts:
VHT FlameProof™ Coating
FWIW, the up-pipes on my 240k mile Excursion didn't leak - until I swapped turbos... I might be tempted to replace the stock up-pipes and donuts with new ones.
2002 FORD F-250 SUPER DUTY Parts - Tousley Ford Parts Depot
Also, this is a good time to do the $0.50 mod if ya haven't yet.
Crewcab Turbo
21
11-26-2011 01:43 PM
