1986 351w 4 bbl carb type & hp rating. - Ford Truck Enthusiasts Forums
Old 12-31-2003, 06:20 PM
tm winchester tm winchester is offline
tm winchester is starting off with a positive reputation.
Does anyone know what carb came stock on a 1985 351w 4bbl F 150 4x4 engine code H Im trying to find out if it was a holley or a ford and the cfm rating,also the HP rating on this engine.
Old 12-31-2003, 09:41 PM
Chris_ce's Avatar
Chris_ce Chris_ce is offline
Chris_ce is starting off with a positive reputation.
hp is around 210. the carb is 600 or 650 cfm and it is a holley carb built only for the fords. I think ford designed it and holley built it.
Old 12-31-2003, 10:41 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
Look at the EFI specs for the engine as it is the same engine just carbed instead of fuel injected. I think its ~215hp and ~320 ft/lb torque.
Old 01-01-2004, 09:45 AM
Thanks guys I appreciate the info.------------------tom
Old 01-02-2004, 12:24 AM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
210 hp and 305 tq. It is a 600 cfm 4bbl that is a 4180 holley carb. They are emssions type carbs but i know from experience that they will burn gas.
351C 2V HP rating ladiabla74 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 17 12-25-2015 08:02 AM
1955 F100 351W Carb / Fuel Pump Question DGMFORD 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-15-2011 01:19 PM
351W: 2bbl or 4bbl? calazo Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 06-04-2004 04:12 PM
CFM ratings for two-bbl. carbs Chuck 6083 Fuel Injection, Carburetion & Fuel System 0 03-25-2003 08:13 PM
HP & Torque 351W Bill M. Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 01-03-2000 12:15 PM
Tags
1986, 351, 351w, 4v, ao, bronco, carb, carbed, engine, ford, fotd, horsepower, hp, rating, spec, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
