73 High Boy Swapout - Ford Truck Enthusiasts Forums
73 High Boy Swapout
Old 12-31-2003, 01:14 PM
Gramps Toy Gramps Toy is offline
Gramps Toy is starting off with a positive reputation.
73 High Boy Swapout
I have a 73 High boy that I am in the process of changing out a stock 360 with a 83' 460 that will eventually be blueprinted and balanced. What pedestals do I need? Will a 83 Ford 2 wd pedestal set work? Can I modify my current pedestals? Does the swap create any driveline issues?
Thanks for the help in advance!
Old 12-31-2003, 05:44 PM
FordPickup460's Avatar
FordPickup460 FordPickup460 is offline
FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.
The is a different bellhousing bolt pattern for the 460, you will need a different bellhousing or transmission. Assuming that your truck is a factory hi boy 3/4 ton, your drive train should hold up behind the power of the 460. I dont know what to tell you about the engine mounts, you should post on the 73-79 room about that, guys have done the swap before there.
Old 09-26-2013, 07:22 AM
General FE General FE is offline
General FE is starting off with a positive reputation.
I'm in the process of building a 73 highboy w my son. He just picked up a 68 429 to replace the 360. Not sure on motor mounts but 351-400 M bell will work. 460 bell is too deep for your 360 four speed. Input shaft won't engage pilot bearing
Old 09-30-2013, 08:28 AM
Monsterford34 Monsterford34 is offline
Monsterford34 is starting off with a positive reputation.
I am almost positive that you are going to need different motor mounts. If my memory serves me right, the 429/460 has the same mounts as a 351m/400. Being the 360 is a fe motor, it has a different mount altogether.
Old 09-30-2013, 09:25 AM
Yeah I was pretty sure the FE mounts wouldn't fly just wasn't too sure if the Mod mounts would. I'm also wondering about the flywheel. If the 390 flywheel bolts up and was from an internally ballanced motor I'm thinking it would be ok? Also found out Ford changed wheel bolt pattern to metric mid1997 while shoping for wheels and tires. Thanks!
What can cause my turbo to keep failing? ssyputa 1999 to 2016 Super Duty 7 08-18-2014 12:46 PM
Glow Plug Relay question X1Lightning 1999 - 2003 7.3L Power Stroke Diesel 10 04-02-2014 03:28 PM
99.5-2003 7.3 SD turbo pedestal OldWoodsDiesel WTB - Parts & other 2 01-19-2014 07:57 PM
I want to go with non-ebpv pedestal ed_stoner38 1999 to 2016 Super Duty 2 01-08-2014 10:25 AM
Turbo pedestal, & turbo parts.. greenstar 1999 - 2003 7.3L Power Stroke Diesel 7 12-08-2013 04:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
