429 Help...
Old 09-20-2013, 01:16 PM
berry1234's Avatar
berry1234
berry1234 is offline
429 Help...
I am looking for a 429 for a 1994 F700. 1)Does anyone know if these are different than the motors found in non-heavy duty trucks?
If so, can anyone help me locate a crate or rebuilt 429 for this truck? Thanks.
Old 09-20-2013, 01:40 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,588 Likes on 1,294 Posts
Your prior post has a source:
https://www.ford-trucks.com/forums/1...ne-source.html
429s were never used in light duty trucks other than the Ranchero. The 429 in mediums like yours is different from that engine, and different from the PU/car 460s, making a direct swap impractical.
"Different" as in crank snout, mounting, accessory drives, bell, clutch, pilot hole in crank, along with the heads, intake, exhaust etc.
Old 09-30-2013, 08:36 AM
Monsterford34's Avatar
Monsterford34
Monsterford34 is offline
It can be done but not recomended. The 429 for trucks used a steel crank I believe as compared to a cast crank. They had calcium I believe in the heads also. One thing though is what will you be using the truck for?
ford4v429
11-28-2012 08:32 PM
nothercrash
09-23-2010 10:43 PM
1950t
12-26-2005 06:02 PM
BlueOvalfan85
03-06-2005 07:09 PM
scottie2hottie
12-13-2004 11:44 AM
Quick Reply: 429 Help...
