LaLa, the 02 in referance uses the OBD II system ,the method you described is for an OBD I system,(Pre-94).And Alfred,I think you are refering to DRIVE CYCLES not cel .The codes can be cleared by the unhook method and the IDLE will reset in two minutes,but you are correct ,the DRIVE cycles take alot longer,there is a method to reset them but it is VERY complicated,such as excelerating from 20 to 50 at 3/4 throttle then coasting down to 20 and doing this three times in a row,and there are about 12-14 things like this that have to be done in order.
