1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
super duty aluminum wheels-center cap mounting
Old 10-20-2002, 04:28 PM
Kurts50's Avatar
Kurts50
Kurts50 is offline
I have a deluxe set of aluminum wheels off a 2002 super duty and will be putting them on a 2003 super duty with steel wheels. The factory aluminum mags have the polished center caps which look like they snap on the lug nuts somehow. Will I have to buy different lug nuts or will these wheels and center caps interchange exactly with the xl steel wheels? Do the caps just snap on the lug nuts or do I need more hardware?? Thanks, Kurt
Durand, IL
Old 10-20-2002, 06:03 PM
redranger1's Avatar
redranger1
redranger1 is offline
the center caps will just snap right onto the old lug nuts no problem! you will need no new hardware.
-nathan
Old 10-20-2002, 10:32 PM
BigDeezil58's Avatar
BigDeezil58
BigDeezil58 is offline
Do all the hubs have the same length studs? Aluminum wheels will require longer studs than steel, but it seems that they all would be the same, and the steel wheels would just have a little more thread showing on the stud. I don't know for sure with the SRW trucks. This was an issue with my dually when I wanted to put aluminum rims on the inside of the rear axle to replace the steel ones. I just decided to leave it alone.
Then I just got rid of the dually...
Old 10-22-2002, 09:50 PM
4x4x4x4's Avatar
4x4x4x4
4x4x4x4 is offline
I went from steel wheels on an 02,SD,SRW to Mickey Thompson Forged aluminum wheels and bought the center caps from the local ford dealer and all went together just fine.
Old 10-23-2002, 07:42 AM
JoeBoost's Avatar
JoeBoost
JoeBoost is offline
I also made the switch from stell to Alum. wheels. I switched from the hole design that came on my Excursion XLT , to go for the Limited wheels. Had no issues at all .
Old 10-23-2002, 06:34 PM
Yeti's Avatar
Yeti
Yeti is offline
Buck Super Duty
21
09-20-2010 05:00 PM
80s Trucker
07-17-2009 07:59 PM
Fords4all
1997 - 2003 F150
08-03-2005 03:52 PM
parochoprs
07-12-2004 11:30 PM
telephoneman
11-25-2001 12:44 PM
Quick Reply: super duty aluminum wheels-center cap mounting
