Getting some brakes or Stopping has been such a habit
Went out to run the engine and keep everything charged and pushed the brake pedal and all the way to the floor. So now instead of changing engines, it's do the brakes. Now the question.....Should I go ahead and change springs, retainers, adjusters and everything? I plan on new wheel cylinders, shoes, and hoses and truning the drums. Should I go with the new silicone brake fluid or will it cause problems?
I have noted prices on wheel cylinders from $19 to $38. So the local places should have things much cheaper, right?
Any idea on total cost?
What a way to start the new year !
Broke Bubba
Broke Bubba
on
Bubba,
Regarding the silicone fluid: It's great for folks like me who live in an area where I have to store my truck in the garage 5-6 months of the year due to salt and snow, but I see you are in South Carolina where you can drive your truck year round. Storage seems to be the worst enemy of brake systems. I don't know that you have a real need for silicone fluid, so I'd just use a high quality Dot 4 fluid. Besides, to switch over you would have to clean out every bit of the old fluid to be sure the new system wasn't contaminated. That means disassemble the MC and blow out all the lines with compressed air. I've found that the best prices on wheel cylinders seem to be at my local parts houses too.
What Scott said. The stuff is too cheap to not replace. We don't want to read any brake failure posts from you. Only exeption might be the starwheel adjuster. Last pair of those I bought scared me a little. It is easy enough to see if it is still useable. Start wire wheeling and soaking in the Liquid Wrench. You can usually restore them to perfect operation with a little patience. Easy on the vice grips or you'll trash the teeth. Heat will loosen them if soaking doesn't work. Put some Anti-sieze on it when they are free. I've restored hundreds of them that were stuck. As long as they aren't an unrecognizable hunk of rust.
AHHHH Gentlemen, Friends one and all. The woman I promised to love honor and take on vacation has loosed the purse springs and said, "well, If I'm gonna ride in the damn thing, you better be able to stop." So it's off to the parts house. She also informed me that we could go Friday and pick up the rest of my Christmas...a shiny new wire welder.... ya gotta love a woman like that. The first part of the christmas stuff was a sawzall and a 4.5 inch angle grinder.
Y'all think I should take her to a chick flick Saturday? Sure want to keep her happy
Happier Bubba
Happier Bubba
on
Originally posted by 55Bubba
Sorry Vern, she's addicted to overfed, grey haired, thinning haired red necks and you probably don't qualify. Thank God for small miracles !
Bubba
Bubba
If your truck sits for any length of time, silicone fluid is the way to go. I've had it in my T-Bird for over a year and have had no problems. An even more expensive method is to have your master and wheel cylinders lined with brass. There's a place called "Brake Cylinder Solutions" on the web that does this service. Anyone out ther use them?
dumptech
10-11-2004 01:45 PM
