NAPA Remanufactured Engines - Ford Truck Enthusiasts Forums
Old 12-28-2003, 08:10 PM
coloradotoy coloradotoy is offline
coloradotoy is starting off with a positive reputation.
Has any one had experience with NAPA remanufactured engines? What cam would be a good choice for a 92 351 that will give a power increase without hurting gas millage? Also this engien has 200k on it, should I replace the injectors or just run them as is?
Thanks
Old 12-30-2003, 05:58 PM
tominator's Avatar
tominator tominator is offline
tominator is starting off with a positive reputation.
I would NEVER trust a rebuild from any parts house!
You'd be better off buying an old motor from a salvage yard and having a local shop build the motor.
If time is not an issue, rebuild the one you have.
Old 12-30-2003, 07:37 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is online now
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
NAPA motors are remanufactured by Delco, and are good quality. I would trust it in my truck in a heartbeat. Autozone and Advance use Recon motors, and I've heard they are all bored .060 over. I know people who have had no problems with those either. The motor from NAPA will probably be a little more expensive, but it's worth it in quality.
Old 12-31-2003, 12:03 PM
daerhldgs2 daerhldgs2 is offline
daerhldgs2 is starting off with a positive reputation.
for a good cam go to Crower cams and get one with a 112 or 114 LDA and this will work well with efi, they are good and reasonably priced.
Old 12-31-2003, 12:22 PM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputation
I've been running a NAPA remanufactured engine about a year and a half now. I'm satisfied with the quality and performance. It has a 3 year/unlimited milage warranty.
PCM replacement/remanufacture frankiethethumper 1999 to 2016 Super Duty 1 11-08-2014 09:39 AM
Difference in injectors Blitzcraig Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-11-2013 06:46 PM
Replacing Brake Booster Check Valve LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 06-01-2010 10:10 PM
Remanufactured 351W Fracster Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 09-21-2002 01:21 AM
remanufactured engine tag rodr 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-19-1999 12:56 PM
Tags
350, 50, advance, autozone, engine, engines, ford, motor, motors, napa, performance, rebuilt, reman, remanufactured, supplies
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
