4.0 V-6 Exhaust Manifold Bolt Torque Specs - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-28-2003, 08:05 PM
swampdog2002 swampdog2002 is offline
swampdog2002 is starting off with a positive reputation.
Hello all,
I recently replaced an exhaust manifold gasket on my 1994 Ford Ranger equipped w/ a 4.0 L V-6, and am in need of the torque specifications for the six (6) manifold bolts. Is there an online service manual somewhere where I can access this information? Any information would be greatly appreciated. Thank you.
Old 12-28-2003, 08:16 PM
84ford460 84ford460 is offline
84ford460 is starting off with a positive reputation.
Tighten in two steps.
1) tighten to 15-22 ft lbs.
2) then tighten to 52-59 ft lbs.
I'd run it for awhile and then retorque.
Larry
1996 Ranger 4x4
Old 12-28-2003, 08:19 PM
swampdog , I screwed up!
I gave you specs on a 3.0L
Here is the right ones:
1) torque to 20 ft lbs.
Old 12-28-2003, 08:54 PM
Thanks so much! I noticed an exhaust leak the other day from the left side manifold, and was surprised to see that there was no gasket in place after pulling the manifold. The same is true for the right side. I didn't think that it was possible to achieve a metal-to-metal contact seal on exhaust manifolds, but the factory did this. Interesting. Thanks again!
Old 12-28-2003, 08:57 PM
Yeah,
I worked on a friends Dodge that was like that. No gaskets just machine fit.
Larry
Head installation 4.0 91 ranger ohv whale15 Ranger & B-Series 2 05-16-2015 07:22 PM
2003 ford e250 4.2l exhaust manifold nut torque spec? F-WhiteThunder 1968-2013 Full Size Vans 0 09-19-2014 10:23 PM
Exhaust Manifold Torque Pollack Pete 1997 - 2003 F150 2 09-24-2010 06:03 AM
Exhaust Manifold Torque Specs fusioncom 1967 - 1972 F-100 & Larger F-Series Trucks 8 06-30-2006 09:52 AM
Exhaust Manifold Torque specs? Smokejet Exhaust Systems 4 07-30-2004 06:39 PM
Tags
1994, 1996, 2003, 40, 40l, 94, bolt, exhaust, ford, manifold, mustang, ranger, specifications, specs, torque, touque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
