4 speed doesn't want to go into 4th.
Ocasionally, mostly in the moring on my trip to work while the truck is still cold, when I try to shift into 4th the gears grind and it won't let me in. I have to put it back into 3rd and then try again. It is like the syncros just quit working for an instant. It only does this once then the truck is good for the rest of the day
Does this mean that my syncros are going out or is it just a trait of of the 4-speeds when they are cold?
I just put the tranny in and don't want to tkae it back out to re-build it.
well now that is is below freezing it is doing it again.....so I have been letting the truck warm up for 5-mins before I drive and that has been fixing it but I wonder if my syncros are going out?
Also if it does sound like syncros is there an "easy" way to change them with the tranny still in the truck?
I pondered lifting the engine part way out......enough to slide the main drive gear out a little and taking the t-case off to pull the main shaft out a little..... anyone ever done this?
7.3 forever
30
08-14-2014 08:35 AM
Corn
03-31-2010 11:36 AM
