head light assembly on 1993 f 150
If i remember, first remove the two cross point screws on top of the headlight grill assy. Then remove the two 10mm nuts on the backside of the headlight assy. They are hard to get to sometimes. One is in the corner. If you are removeing the right head light, you need to remove the battery and the tray i think. its been awhile. Good luck. DP in NC.
texas_tech_guy83
Electrical Systems/Wiring
13
08-14-2021 12:27 PM
