Water Pump Removal On Ranger Edge
Welcome to FTE!!!
This is the basics, let us know if you need more details.
Water Pump — 3.0L
Removal
1. Disconnect the battery ground cable (14301). For additional information, refer to «Section 414-01».
2. Remove the air cleaner outlet tube (9B659). For additional information, refer to «Section 303-12».
3. Remove the fan blade (8600) and the fan shroud (8146). For additional information, refer to «Shroud—3.0L and 4.0L» in this section.
µ 4. Disconnect the water bypass tube (8555).
5. Remove the accessory drive belt (8620). For additional information, refer to «Section 303-05».
µ 6. Remove the bolts and the water pump pulley (8509).
µ 7. Remove the bolts from the A/C compressor mounting bracket (2882).
µ 8. Disconnect the lower radiator hose.
µ 9. Remove the bolts and position the bracket and compressor aside.
µ 10. Remove the bolts and remove the water pump (8501).
Water Pump — 3.0L
Removal
