Water Pump Removal On Ranger Edge - Ford Truck Enthusiasts Forums
Old 12-27-2003, 09:55 PM
hwjohnston hwjohnston is offline
hwjohnston is starting off with a positive reputation.
What all is involved in pulling the water pump on my Ranger Edge , 3.0 6CYL.?
Upper Case edited out by FTE
Old 12-27-2003, 10:09 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
If you go to the FTE forum page and scroll down you will find a Ranger "area" try that.
Hope you find your answer
Old 12-28-2003, 06:59 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Welcome to FTE!!!
This is the basics, let us know if you need more details.
Water Pump — 3.0L
Removal
1. Disconnect the battery ground cable (14301). For additional information, refer to «Section 414-01».
2. Remove the air cleaner outlet tube (9B659). For additional information, refer to «Section 303-12».
3. Remove the fan blade (8600) and the fan shroud (8146). For additional information, refer to «Shroud—3.0L and 4.0L» in this section.
µ 4. Disconnect the water bypass tube (8555).
5. Remove the accessory drive belt (8620). For additional information, refer to «Section 303-05».
µ 6. Remove the bolts and the water pump pulley (8509).
µ 7. Remove the bolts from the A/C compressor mounting bracket (2882).
µ 8. Disconnect the lower radiator hose.
µ 9. Remove the bolts and position the bracket and compressor aside.
µ 10. Remove the bolts and remove the water pump (8501).
belt squealing bulla 1999 - 2003 7.3L Power Stroke Diesel 37 03-23-2016 09:17 AM
coolant leak - unsure origin tomboy67 Ranger & B-Series 6 04-05-2015 01:21 PM
Difference in Edge vs. Ranger Sport? jwh2car Ranger & B-Series 10 09-28-2009 10:58 PM
Need water pump part.# 02 Ranger B 3000 Ranger & B-Series 1 03-12-2009 09:18 PM
Whats the difference? XL - XLT - EDGE jippy Ranger & B-Series 5 10-16-2002 08:24 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1989, 2001, 2002, 30, 30l, change, duratec, ford, location, pump, ranger, removal, remove, tube8555, v6, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
