how do I replace the ignition switch on my f150? The key goes in but it will not turn. I have been having trouble recently with the tumblers lining up and inserting the key.
I had my 92 ignition switch out a long time ago, I think it was a pain in the butt. I believe there are two bolts with a special head that can only be tightened, when you try to loosen them there is no way to hold the screw.
I would try to lubricate the key tumblers, and, like the last reply mentioned , to rock the steering wheel one way or the other.
