5.8 high output? - Ford Truck Enthusiasts Forums
5.8 high output?
Old 12-27-2003, 04:38 PM
T/A Man T/A Man is offline
T/A Man is starting off with a positive reputation.
5.8 high output?
How do I know if I have a 5.8 high out put in my 92 F-250 heavy duty? The former owner says that is what it is so I am intrested to know what the differance is between the HO and the standard 5.8. Thanks Jack
Old 12-27-2003, 09:23 PM
modru2004 modru2004 is offline
modru2004 is new and has a neutral reputation at this point.
im curious as well as i have an 5.8 ho in my truck as well but still don't know what is different.
Old 12-27-2003, 10:17 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
I believe the 5.8L HO's were the fuel injected engines which came out in '88 and stamped with the code "H", the earlier carb'ed 351's were just regular 351's. The "R" code 351's were found in the GEN 1 L's 93-95, and those shortblocks may have been in a few regular F series pickups, but I can't say for sure.
One of the differences between the regular 5.8's and the H.O.'s were the heads, cam, and the addition of EFI. From what I've read, the heads on the ealier models are just 302 heads with 1/2" head bolt holes. The mid 90's and later HO 5.8 blocks were drilled and tapped to accept a spider (and stamped with a "F4TE" type code that is near the starter) for a roller conversion, and in mid/late 96 some actually came with roller cams from the factory.
Old 12-28-2003, 12:36 AM
mrwizard's Avatar
mrwizard mrwizard is offline
mrwizard is starting off with a positive reputation.
My carbed '85 Bronco had a 351HO. Don't know what the difference was though.
Old 12-28-2003, 07:37 AM
dk5122 dk5122 is offline
dk5122 is starting off with a positive reputation.
My 87 F-250 has a 351 HO with a carb. on it. Not sure the difference between the two but someone around here does.
Old 12-28-2003, 10:30 AM
Blurry94's Avatar
Hmmm...I didn't know that the HO's went back that far, unless the earlier HO's were equiped with 4bbls???
Old 12-28-2003, 10:34 AM
fordin K fordin K is offline
fordin K is starting off with a positive reputation.
My friend has a H.O. 5.8 on his '84 carb'ed and 4v also head design flow.
Old 12-28-2003, 01:01 PM
yes but we are wanting to know about 88+ 351 HO engines with fuel injections.
Old 12-28-2003, 02:04 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
The only thing I can think of is there may be a difference between the 351's in the F150's and the 351's in the F250's and up. I think there are some emissions system differences, but I'm not sure what else. Horsepower and torque ratings should be the same as far as I know.
Old 12-28-2003, 04:24 PM
why would they be called high output then? and the 87 older ho engines had different hp and torque ratings. mines an f-150 but my grandad when he bought it new had the better engine put in at the factory.
Old 12-28-2003, 09:29 PM
modru2004 why don't you go find out and tell us what the difference is. Seems that the same upgrades they did to get a 5.0 to a 5.0 HO they did to the 5.8, except I am not sure on the cam. Can't you just look on the upper intake manifold and it says 5.8 H.O. !!! as far as I know all came like that. But I don't know because I run a straight six............ with a 351w L.O. waiting to go in from the garage.
Old 12-28-2003, 11:18 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
The actual "H.O. 351" was phased out in '87. It was a stock block with a bigger cam, and a holley 4bb carb, they also put better heads on it. I have a '92 E150 with a 351 H.D., which is similar to the HO, the throttle body is ~56mm instead of 49 or 51mm (I forget the stock size) and the upper intake runners are a little longer.
Old 01-16-2004, 02:42 PM
cars4bubba cars4bubba is offline
cars4bubba is starting off with a positive reputation.
So...all that being said...Does anyone know what the HP ratings are for the early 90's 351HO? Thanks!
Old 01-16-2004, 04:03 PM
Quote:
why don't i go out and tell you the difference? because im not a frigin mechanic. i don't know that much about the engine thats why im here, you really think i would be able to tell you the difference when i don't know the exact specs of the reg 351? yes just because i have the dang engine im a super genius mechanic that knows everything.
5.8L EFI 351W Headers? a11jack3dup 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 03-07-2010 04:32 PM
'95 5.8L Oil Pan 66F100Again 1987 - 1996 F150 & Larger F-Series Trucks 4 08-27-2007 12:04 PM
what is a 5.8 HO?? nwmud Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 17 03-29-2006 09:10 AM
92 5.8 firing order???? T/A Man 1987 - 1996 F150 & Larger F-Series Trucks 2 12-07-2004 11:41 PM
Radiator Hoses JoeB 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 09-19-2000 10:37 PM
Tags
58, high, output
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
