1001 uses for Zip Ties - Ford Truck Enthusiasts Forums
Old 07-10-2002, 08:00 AM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
Ok, we've all seen 1001 uses for Duct Tape, everything from covering rust holes in your truck to making the cat walk funny, and we know there are over 1001 uses for WD-40 (I believe Henry Ford would have used the stuff for hair spray). Now list all your uses for Zip Ties. I'll start,
Fix dishwasher rack
Key ring
Bicycle spoke clackers
Hold parking brake cable to frame until get repair part
Fasten kids bicycle name plates
Fasten hanging plant to awning support
Old 07-10-2002, 09:29 AM
HotWhlz85's Avatar
HotWhlz85 HotWhlz85 is offline
HotWhlz85 is starting off with a positive reputation.
Ok, the obvious first;
Tying wiring or cables together
Handcuffs (best left to the cops)
Securing loose objects (either permanently or temporarily, insert name of favorite loose objects here)
Not so obvious;
Dog choke collar (only works once per dog)
body piercings (remember rubber bands?)
hinges for a swinging door/gate
loops for hanging tools, fishing rods, etc out of the way in the garage
That's all I can think of right now, but 1001 uses is probably just scratching the surface.
Ron
Old 07-10-2002, 09:41 AM
TheWiz427's Avatar
TheWiz427 TheWiz427 is offline
TheWiz427 has a good reputation on FTE.TheWiz427 has a good reputation on FTE.TheWiz427 has a good reputation on FTE.
Hmmmm let's see
Fasten dryer vent to dryer
Straping the coax to the side of my tower
Tieing up the loose wires under the dash
Holding up a bumper till i could get it fixed
Ocasionaly use them as trash bag ties (only as last resort)
Holding up Christmas decorations
Hanging the beware of dog sign on my fence
Just to name a few
Wiz
An Equal Opportunity Truck Lover!
http://www.clubfte.com/users/thewiz427/index.html
Old 07-10-2002, 09:59 AM
theologian's Avatar
theologian theologian is offline
theologian has a good reputation on FTE.theologian has a good reputation on FTE.theologian has a good reputation on FTE.
Great for attaching tactical slings to the forends of Carbines.
depth stops on drill bits.
splints for sick trees.
Securing broken posthesis.
Adapting Truck seats to fit accurately on the frame of electric wheelchairs (done it, lasted for over a year no problem)
Balancing ceiling fans.
using as a pick to scrape bits out of the actions of pistols.
using as a rough and ready gun lock. (does keep tots safe)
Plus all of the obvious ones.. That is all i can think of in the few minutes I had spare, Maybe I can think of some more later.
Wm
'96 F450 White with Grey interior Crew Cab. Banks Turbo, Intercooler and Exhaust,
Power pack Chip, shift kit, Auxiliary transmission, electronic enhanced transmission control,
16 forward and 4 reverse ratios. 340hp 660ft lb 4 wheel drive, 4.10 gears, 12,ooo# winch
Old 07-10-2002, 12:25 PM
alanscott's Avatar
alanscott alanscott is offline
alanscott is starting off with a positive reputation.
Sheep herders use them for castration. Ouch
Old 07-10-2002, 12:59 PM
1970f2504x4's Avatar
1970f2504x4 1970f2504x4 is offline
1970f2504x4 is starting off with a positive reputation.
Aside from all the obvious ones:
Practical Joke - Place a big ol' zip tie on the drive shaft of someone's car or truck. "Do you hear that noise??"
James Kern
1970 F250 4x4
Old 07-10-2002, 05:50 PM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
I can't add any unique uses to this board, but I will second the notion that they are most certainly on the list of fine products that will always adorn my garage!
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old 07-10-2002, 05:57 PM
wolfmanagh's Avatar
wolfmanagh wolfmanagh is offline
wolfmanagh is starting off with a positive reputation.
Toothpicks
I've seem someone use them to hold the straps on their overalls
I doubt there is as many uses as the "handy mans secret weapon" duck tape.
Old 07-10-2002, 08:45 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
holding the grille in on a 79 F-150
keeping loose wires hidden under the dash
used in place of a small bolt to hold the coolant recovery tank in place (previous owner's work)
[font color="green"]1995 F-150 Supercab XLT 4x4 302 M5OD 8' bed [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old 07-10-2002, 11:18 PM
STR8 SIX STR8 SIX is offline
STR8 SIX is starting off with a positive reputation.
-hold 2 piece fishing rods together
-Pant gaters....holds my jean pant legs down when I put on my chest waders
I have used duct tape for the gater part as well
-used to hold a flapper onto the exhaust of a friend's tractor....had to replace often
-Hand cuffed my niece just cuz she did not believe I would do it. She was stuck for about 30 seconds till the whining became unbearable
-makes our lawnmower keep running even when you let go of the bar
-ditto with the snow blower
That is all I can think of now....
Old 07-10-2002, 11:45 PM
canadianfordman canadianfordman is offline
canadianfordman is starting off with a positive reputation.
I use one instead of a key for my trailer hitch pin, saves someone walking buy to steal it unless they have a knife, and its much cheaper then the lock.
I also use one to hold all my other ones together, ehh Hows the for impressive.
Old 07-11-2002, 06:56 AM
BrettCox's Avatar
BrettCox BrettCox is offline
BrettCox is starting off with a positive reputation.
Ethanol in my v 10? KP1001 Modular V10 (6.8l) 9 05-27-2016 10:57 AM
Sounds like my neighbor will sell me his truck... What's it worth???? 1972Herbie 1961 - 1963 F100 Unibody 1 04-14-2015 03:58 PM
Bought my neighbor's 1963 F100! 1972Herbie 1961 - 1966 F-100 & Larger F-Series Trucks 11 12-17-2014 08:25 PM
What's it worth?? 1963 F-100 1972Herbie 1961 - 1966 F-100 & Larger F-Series Trucks 15 10-27-2014 01:51 PM
Trying to buy this truck off of my neighbor... Need some parts! 1972Herbie 1961 - 1963 F100 Unibody 0 09-22-2014 11:15 AM
Tags
1001, bicycle, car, castrating, castration, castrator, clackers, dogs, repair, spoke, tie, ties, wd40, zip, zipties
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
