Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
17 inch wheels on a Lightning?
Old 12-24-2003, 02:19 PM
02Lariat's Avatar
02Lariat
02Lariat is offline
ok, i want to upgrade the brakes on my 02 lariat by putting the lightning rotors on it, the rear brakes are the same already. but i called the ford dealership and the spindles are the same also so all i need are the caliper brackets, rotors, and calipers(no problen since i work at O'reilly's) but i want to make sure that the brakes will fit in my wheels, i know an L has like 18 inch wheels but if i have to upgrade my wheels to fit the brakes i don't think i'll be able to get them(i think maybe it'll fit because i have 17 inch wheels but i have to make sure first.) thanks in advance, justin
Old 12-29-2003, 12:03 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Try and find out the diameter of the rotor of then new brakes, and then measure how much room is in your wheel.
Old 12-29-2003, 06:27 AM
The Swede's Avatar
The Swede
The Swede is offline
It will fit , i got 16 inch for my slicks !
Old 12-30-2003, 12:43 AM
02Lariat's Avatar
02Lariat
02Lariat is offline
well i looked around in the computer at work and i think i found that the lightning brakes are the same as the brakes on an expy. but only if the nascar truck has the same rotors, a local wreckin yard also says the caliper brackets are the same from L to expy
the peppermint
Projects
39
08-12-2015 09:15 PM
Roadbird
11-05-2014 08:29 PM
powerstroker02
1966 - 1977 Early Broncos
06-02-2010 09:33 AM
wetsu1
1999 to 2016 Super Duty
13
10-26-2009 12:26 PM
highboy 74
05-30-2005 04:10 PM
Quick Reply: 17 inch wheels on a Lightning?
