BG 44k fuel additive - Ford Truck Enthusiasts Forums
Old 12-23-2003, 09:35 PM
ltfox's Avatar
ltfox ltfox is offline
ltfox is starting off with a positive reputation.
I got a bottle of "bg 44k" from a local mechanic and its supposed to be a real good fuel system cleaner. Anybody used it? Is good or bad??
Old 12-23-2003, 10:55 PM
Paarrothead's Avatar
Paarrothead Paarrothead is offline
Paarrothead is starting off with a positive reputation.
Yes, it's got a decent reputation I suppose, I've tried it, didn't notice any difference after using it and I don't think that it's worth $20 a can.
If you can get it in your area, dump 5 gallons of B-100 biodiesel fuel into your truck every now and then. If you've got an older truck, it will effectively remove deposits from your fuel system-
To the point where you might need to replace your fuel filter for all the gunk that gets dissolved. Now, *that's* a fuel system cleaner. And it's a super injector lube, too, which the 44K isn't.
Old 12-23-2003, 11:13 PM
alanscott's Avatar
alanscott alanscott is offline
alanscott is starting off with a positive reputation.
I've used BG 44k in gas engines, but never a diesel. Is it even suggested for diesels?
Old 12-24-2003, 09:02 AM
ltfox's Avatar
The instructions on the bottle I have said to add it to diesel. No mention of gas.
Old 12-24-2003, 07:28 PM
elwood73 elwood73 is offline
elwood73 is starting off with a positive reputation.
ive seen and felt tremendous results with the bg44 triple clean system for gas engines on my buddys firebird and my other friends toyota, the best hundred dollars they ever spent, interested in the stuff they make for diesel.
Old 01-11-2004, 09:14 PM
bk44 can be used in both gas and diesel, they sell a quart sized bottle for diesel but according to my local rep its mearly a larger bottle for larger tanks on diesel trucks, bg makes a product called diesel care, which is pump through a machine and run thourgh the motor like there gas version but none of my local dealers have the machine, the closest dealrer is 100 miles east of my town, in the event im traveling that way i'll schedule an appontiontment a try there product and get back with everybody on the results.
Old 01-11-2004, 10:26 PM
ltfox's Avatar
Used the botlle of the bg 44k that I had. Have'nt checked my milage yet but my truck seems to be running better. More power. Just pulled 4 horses in my gooseneck over the mountian, did'nt drop under 65 mph going over the passes.
BG 44K Anyone tried it? ukexplorer Explorer, Sport Trac, Mountaineer & Aviator 1 09-21-2011 07:35 AM
Hesitation on Acceleration cajunbull61 1997-2006 Expedition & Navigator 5 08-06-2010 03:47 PM
BG44K Fuel Additive tjpresto Modular V10 (6.8l) 7 06-19-2007 08:02 PM
Injector cleaner cobaum 1999 - 2003 7.3L Power Stroke Diesel 11 10-26-2005 08:20 PM
Fuel Injector Cleaner BG44K okcexpo 1997-2006 Expedition & Navigator 11 10-11-2003 10:53 PM
Tags
44, 44k, 44x, additive, bg, bk44, buy, cleaner, diesel, fuel, injector, lucas, treatment, trucks, versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
