4.0 ohv firing order? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-23-2003, 02:28 PM
crackerjack crackerjack is offline
crackerjack is starting off with a positive reputation.
Question 4.0 ohv firing order?
Just bought a '92 Ranger with 4.0 ohv, auto, 2wd, 110k mis. Doing a little tune up, new filters, plugs, wires. I put in standard motorcraft plugs, awsf-42c, gapped at .054, and 8mm Bosch wires. Started it afterward and it runs like crap. I think it's missing on a few cylinders and the exhaust smells like unburned gas. I wondered if I had rewired the plugs in the wrong order. Can someone verify? I read on another board that the Chilton manual has it wrong. Thanks for helping a newbie to Rangers and Ford-Truck Enthusiasts!
The way it was wired before I started...
Engine
654 \ cylinders (front of car-> )
321 /
465 \
321 /
ignition coil pack in order of plug wires(front of car->)
Old 12-23-2003, 02:55 PM
JEY JEY is offline
JEY is starting off with a positive reputation.
crackerjack, - looks like you have it right. Right bank 123, left bank (drivers side) 456. Firing order 142536.
Old 12-23-2003, 03:01 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
You have the engine right but I think the coil is...
456
321
Please correct me if I'm wrong. Also you should always do one plug/wire at a time to avoid this issue.
Old 12-23-2003, 03:42 PM
Ken,
I tried switching the wires between cylinder 5 & 6, and it wouldn't even start. Guess it must be another problem!
Thanks.
Old 12-23-2003, 06:20 PM
Ken00's Avatar
Sorry about that, my memory must be slipping, just checked mine and your right. I would pull one wire at a time until you find the cylinder thats not firing and then swap the wire to another cylinder and see if the miss fire follows the wire. You will need to use something insulated. If it follows then bad wire, if it stays do the same with swapping plugs. Did you use dielectric grease?
Old 12-25-2003, 05:48 PM
fordinlinesix's Avatar
fordinlinesix fordinlinesix is offline
fordinlinesix is starting off with a positive reputation.
I've got the same problem on my '97 Explorer with the 4.0 OHV, except the problem happened after I washed the motor. Man gaskets for the 4.0 are expensive.
Old 01-06-2004, 11:16 AM
rangerx93 rangerx93 is offline
rangerx93 is starting off with a positive reputation.
Crackerjack -
I would seriously consider purchasing a Haynes manual. Less than $20 and includes all specifications for your ranger. I purchased one about 7 years ago and use it every time I do maintenance or repairs, it has never let me down. You can get one, specific to you truck, at Autozone. Hope that helps!
Old 01-06-2004, 06:57 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Quote:
Originally posted by rangerx93
Crackerjack -
Good advice.
P.S. Welcome to Ford Truck Enthusiasts!
Help!! Installed '96 Explorer 4.0 ohv into '99 Ranger Stretchstick Ranger & B-Series 11 07-20-2014 10:47 PM
truck sputters swascott1981 Ranger & B-Series 11 03-21-2012 05:02 AM
1999 Explorer misfiring sometimes zzzJohn Explorer, Sport Trac, Mountaineer & Aviator 5 01-15-2012 12:30 PM
4.0 OHV Valve cover bolt size 792504x4 Ranger & B-Series 2 01-18-2009 09:28 PM
4.0 SOHC to 4.0 OHV can it be done fordnut forever Nebraska Chapter 3 03-08-2008 07:46 AM
Tags
1997, 2000, 2oo2, 40, 4o, 90, explorer, fiing, firing, ford, frieing, ohv, order, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
