Need help with Cam Sensor for explorer 1993 - Ford Truck Enthusiasts Forums
Old 12-23-2003, 12:26 AM
jeaserve jeaserve is offline
jeaserve is starting off with a positive reputation.
Unhappy Need help with Cam Sensor for explorer 1993
I have a 1993 ford explorer. My service engine is on and FORD says the code shows I need a CAM sensor. Where is the cam sensor located and is it hard to replace.
I bought a used one and cannot find where it goes.
Any ides?
Old 12-25-2003, 09:38 PM
nalz nalz is offline
nalz is starting off with a positive reputation.
Cam sensor/synchronizer assembly is at the rear of the engine block, you have to climb on top of the engine and look down just behind the upper intake manifold. BTW these need to be indexed properly just like a distributor, so dont jump into this if your not aware of that , it will just create new driveability issues for you
Old 12-27-2003, 12:27 AM
Thumbs up Thank you very much Nalz
Thank you very much for the info...I have the stats on how to secure the proper installation of the Cam Sensor for the Ford Explorer. JEASERVE
1993 ford explorer sport camshaft sensor?? bflo1220 Explorer, Sport Trac, Mountaineer & Aviator 2 07-31-2014 12:22 AM
Need cam sensor 1993-98 4.0 Explorer fredsheffield 1997-2006 Expedition & Navigator 2 03-14-2010 06:46 PM
Cam Position Sensor 1994 Explorer vtcart Explorer, Sport Trac, Mountaineer & Aviator 4 12-15-2004 11:07 AM
Cam position sensor on 1994 Explorer vtcart Explorer, Sport Trac, Mountaineer & Aviator 0 12-06-2004 10:04 AM
Cam Sensor 1994 Explorer vtcart Explorer, Sport Trac, Mountaineer & Aviator 4 09-24-2004 06:26 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1993, cam, camshaft, exploer, explorer, exployer, f150, ford, senson, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
